EXT: Valve Cover Painting (w/ pics)
    Hey guys, I know this outta be in the DIY section but I can't post there quite yet. This is a mighty nice art project that can make your generic little F22 reflect how much work you've done on the inside.
    Whatcha need:
    -a valve cover (dur!) mine was $9 from a u-pull yard
    -sandpaper- 100, 300, and 600 grit size
    -paint stripper- just like .5L
    -toothpicks for the tiny cracks
    -a dropcloth or trashbag
    -hi-temp primer, paint, and clear coat
    -other useful stuff like foam brushes, paper towels, etc
    -(optional) a fine tip dremel sander for small corners
    How to do it:
    1) clean off your cover with soap and water since it's gonna be covered in oil and road grime
    2) paint on a layer of goopy paint stripper. **this stuff is really toxic and can burn skin off really quick! Also, only pour it into metal or glass** Rinse with water and alot of paint will come off. You might want to do this twice and make sure you get into the cracks.
    3) dry it off to keep the inside from gettin rusty. Only took like 10mins since it was like 150deg that day
    4) sand off the last few bits of paint with 100 grit paper and make a pretty even surface (it'll have some hefty scratches in it) Wipe it off b/n sets to keep from filling your sandpaper with dustiness.
    5) do the same with the 300 and 600 grit paper until it looks smooth.
    (side note: if you do well enuf, it'll look like brushed aluminum after the 300g and you could just clear coat it)
    6) wipe it clean again and go back outside. Using loooong, even, light strokes, put down a layer of primer. Do it like the pro guys do with air guns! Too thick and it'll run and you can't fix that too easy. Wait 15mins and do another.
    7) do 2-3 layers of your color paint depending on how you like it. Same way with really light, even coats. If it's too humid to dry, run a fan next to ya or else all the random dust will stick to it!
    8) Sand the emblems back to metal and do a layer or 2 of clear if you want. It'll make it glossier and keep it from getting nasty as fast. Still got some touchups to do on my "H" but I fixed that.
    9) let it dry for at least 12h and the lay it on some foil in a 200F oven for 20mins to set it. Don't let any oil fall in the oven or it'll smoke. You should be fine over foil or a big tray.
    10) go show off how uncharacteristically awesome your little single cam motor can be! Be creative and try patterns and stencils. I'd stay away from trying to match intake and spark plug wire colors, it never turns out quite the same.
    Good luck to ya all and CB7tuner rulez!
    Shankenstein
    Nice, you got a finished pic on your car?
      Sweet, looks good. Are you going to sand down the logo and lettering?
        nice job.
          -yeah the sanding looks pretty good as long as you keep all the scratches in the same direction. Make sure it's all the way dry first or else the shavings get sticky on the rest. I bet a black H would be nice, or maybe red (superman anyone?
          -and it's not on yet. I'll save the trip (and gasket) if I can ever get around to putting in my PT6 and A6 cam. THAT really needs a DIY for the engine novices
            Looks good! Def get a picture up of the finished product in the engine bay! Im gonna do mine hot pink. Haha. But i need to find high temp paint.
              that'll be fun to see the results! You can get the paint from any chain auto store. Don't bother with Lowes or HD, they tried to sell me paint for BBQ grills instead
                If you have the heat resistant primer and clear then the any spray paint should work fine with heat.
                  i did that in red but i sanded down the lettering
                  They rise their wooden pints and they yoik and sing
                  And they fight and dance 'till the morning
                  Dont forget my MRT for my 1992 Honda Accord LX
                  Everything in Japan is made with carbon fiber and used panties.
                    this should be going the DIY since its so freaking sick, I feel like doing it now lol.
                    one question though did you reuse the old gasket? If so, did you have to put some type of silicone on the gasket?
                    and What are the torque specifications?
                    sorry for all the question
                    Originally posted by visualpoet
                    some owners think it's the best thing since titties
                      Looks kinda like mine.
                      Nice DIY.
                      Click picture for MRT
                      Sparkin CB7
                        So for everybody who wants to see it on the engine... it looks EXACTLY like ^^^ that! Good job Bach, did you use the Dupli engine enamel? I'm jealous you beat me to the install but I'm gonna see if I can rough sand my cheezy SR intake tube and stock brake calipers to match.
                        (ps. if the mighty Deev is watching, feel free to move this to the DIY section, it's kinda out of place here)
                        ~Shankenstein~
                          Yup I used the Dupli engine enamel.
                          I really need to clean my engine bay. It's dirty and has oil on the block from the gasket being so dry and cracked.
                          But thanks, Took my time and it obviously turned out pretty good.
                          I think yours is better and will last longer because I didn't use paint thinner and sand off the OEM paint. But oh well if it chips or starts to look crappy I'll redo it and do it your way.
                          Sparkin CB7
                            Sweet. So high temp primer / base coat. Hot pink. Then clear coat. Haha. HOT PINK VALVE COVER coming soon.
                              Good job, ugly color.
                              wat?
