DIY- Day Time Runninglight Delete
    Okay, so in Canada every car is required by law to have daytime running lights. They are a fantastic idea, the only problem is that as soon as the car is put in gear the DRL is the lowest the headlights will go when you try to turn them off. We thought this weekend that it would be neat to be able to not have them, but only in certain occasions.
    This is also my first attempt at a DIY
    Parts
    -About 4' of wire (x2) (I used speakerwire)
    - 1 Automotive grade rocker switch.
    - 1 10amp fuse holder
    - electrical tape
    -heatshrink tubing
    Tools
    -Rotary tool with small carbide type bit
    -Phillips screw driver
    - Soldering Iron
    - Ruler
    -Sharp knife
    - Wire cutters
    - Wire strippers
    Other
    Safety Glasses
    Stage One
    Step 1
    Pull 10amp fuse in the DLR section of the fuse block.
    Check for result before proceeding.
    Step Two
    Run one end of the fuse holder into one plug in the original fuse holder. Connect one end of the run of wire to the other end of the original fuse plug.
    Step 3
    Connect other end of wire to the other end of the fuse holder.
    Step 4
    Now insert the fuse
    You should have something of a circuit formed running back with two joined wires coming out smilar to this.
    Stage two
    Step 5
    Run those wires out through the opening and back through the grommet in the firewall and then under the dash.
    Step 6
    Remove the Glove box. There are two little screws on the bottom, as well as one on the arm on the right hand side.
    Step 7
    Measure your switch, and use the Rotary tool to cut out the right size. I came in through the back side of the box.
    Make sure there is room behind the box to fit the switch in
    It should look like this. You will notice the hole from not checking my clearance.
    Step 8
    Then solder on the wire ends to the switch ends. Seal each connection, as I hope you would have on all connections.
    Before:
    After the switch is hit
    Cheers!
    sweet, but we want them!
    couldnt you just switch the power wire running to the relay under the dash? wouldnt that be easier?
    smoke tires, not drugs.
      you should just remove the DRL unit and sell it to these wierd guys that want the GM look, lol. later.
      Avoiding dirt at all costs
        x3. There are plenty of Americans who want it. Just trade setups, lol.
        Originally posted by Jarrett
          wont work...
          we need the interior harness or something.
          i have a relay and i figured u.s and canada...same continent why not same harness, lol well i was wrong.
          im sure we could wire it somehow, but its probably a bigger pita than anything.
          funny how canadians want them gone, and americans want them in
            It's true. Your responces made me chuckle. It's like how we go crazy over JDM headlights, yet the Malysaian users on this site all want USDM stuff.
            I like DRL, I just wanted a quick option to run my car with no ilumination at the flick of a switch. For times when you are driving somewhere you shouldn't, or when you are hiding and dont want to turn your car off.
            We were going to run into the harness, but this way my car is easily returned to factory specs provided I sell it. And as for pulling it all together, I could just leave the fuse out, but I wanted to keep the car saftey-able and not get pulled over.
              Like you said Jake, we have so much jdm that even jdm is out of jdm.
              We want what they dont want and vice versa.
                also a good idea, stock-ness is a good selling point!
                haha i love the sig, after i said it i thought thats getting sigged sooner or later
                  Wish i had DRL's
                  I'm So JDM My Heart Is On The Right
                  Cappuccino Member #11
                  G-Square For Sale PM Me.
                  Rear Fog For Sale PM Me.
                    i'm in canada too but my car doesnt have drls... dunno why though, got it this way.
                      I dont like DRLS cause they waste the life of your bulbs :/
                      -Will
                        Wonder if that would lower your insurance
                          I want DRL high beams.
                          Follow me on IG: @jdm_inspired
                          93 'til infinity
                            thats what i have.
                            Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
                            -(B-Pillar Bar Originator)-
                              It is a good idea to have them. You wouldn't think so until your hit head on because someone didn't see you. Even in broad daylight. Cops told me that I wouldn't have been hit in my old '92 if my headlights would have been on. I actually like that my S10 has DRL's.
                              Originally posted by chessboxer
                              We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
                              Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
