Headlight/highbeams problem
    I bought the car like this: when I turn the lights on, the right headlight works fine. The left headlight is on but VERY dim. I switched the bulbs, and they're not the problem. My bro said it could be a grounding problem. Another problem I'm questioning is my highbeams are also on all the time, but very dim. When I actually engage the highbeams, the low beam lights turn off and the high beams come on.
    I'll try to take a picture when I can.
    Sounds weird! Have you checked the fuses under the hood bro?
      Its the DRL module (Daytime Running Lights) Located up under the drivers dash. A bitch to get out. Some are black and some are grey. They are not interchangeable.
      GOT F?
        ur bro is right, one of my couzins had the same problem wit his chevy tahoe ss10, the right 1 was good but the left 1 was dim, n it was a ground cable not conected and we just conected bak the cable n that was it, i think thats ur problem also, for the highs i dont kno..
        AT WEST COAST MEET
        cb7rush: who has the tongs?
        JDMxDB8: i got a thong on...
        to get to see more of my cb click the link below.
        http://www.cb7tuner.com/vbb/showthread.php?t=130922
          Yeah. They're good.
          After I get to the DRLs, what do I do?
          yeah, I'll check have to check that out again.
          thanks guys!
            I haven't fixed the problem yet, but I do think I know what the problem is. It's not a grounding problem. When I turn my headlights on, I take out the fuse for the left headlight, and nothing happens. When I put the left h/l fuse back in and take out the right hl fuse, all the headlights turn off. Whoever messed with the wiring did something and used all the power for the right headlight to power all the headlights. I have no idea how to fix it. Anybody got any suggestions? If not, how much would it be to have somebody fix the wiring?
            thanks guys.
              our cars in the US don't have DRL's.
              sounds like a grounding problem to me. later.
              Avoiding dirt at all costs
                trace the wires behind the headlights. someone cut into it somewhere, so find that and undo their handywork. but then you will have the problem that they tried to fix to deal with. good luck
                Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
