Preventing Front bumper "sag"
    My front bumper seems to not meet up with the headlights properly, it looks like its hanging down further than it should what can I do to fix this?
    The CB7 Collector.
    92 LX Coupe F22A1
    2013 Toyota Corolla S
    92 EX Sedan F22A1
    Check to make sure all the clips are still there,
    if not replace them....
      Where would i go to get replacements? I know not all of them are there
      The CB7 Collector.
      92 LX Coupe F22A1
      92 EX Sedan F22A1
        replacements can be found at honda, junkyard, sometimes you can find a suitable replacement at a local auto store.
          I held the bumper where it's supposed to be and shot some 1 1/2" self-tapping sheet metal screws into it. It will never sag due to broken plastic clips again. The grille hides the row of screws across the top.
          Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
            My Bumper needed some replacement Clips . took a ride over to Auto zone and found some GM Plastic Clips and Did the job
            Check Out My Work In Progess . . . . .
              pics help out a whole lot.
                yeah chances are you just didnt have somone else pull up on it while you tightened the bolts.
                try that before you go buying things
                  Yeah, What I do is I use a really long extension on the lower 12mm bolts and pry up on the bumper while tightening them.
                  wat?
                    Clip is gone or doesn't slide in right.
                      Honda would have replacement clips their probaly like 20 cents each...or you can use zipties lol
                        Will zipties work? Never tries it before.
                          My driver side chip off a little so I used ziptie....Work great..
                            zip ties will work, but i would prefer clips....
                              Looking good. Feeling tha arcadia green and the front end.
