Would a 17" rim fit in a CB9 without any modding? Would this decrease my performance too? I prefer performance over look and black rims with silver or red highlights if that helps.
Larger Rims on CB9?
Larger Rims on CB9?
Current:
2007 Acura TL Type-S 6MT KBP
Past:
1992 Honda Accord EX-R Sedan - RIP
1991 Honda Accord EX-R Wagon - RIP 10/14/2010
Words change lives. You just got to choose the right ones.
Instagram: @CB7Nub
Check out the more active "CB7Tuner Canada" Facebook group for CANADIAN members ONLY.
Tags: None
Originally posted by CB7Nub View PostWould a 17" rim fit in a CB9 without any modding? Would this decrease my performance too?
Yes. Engine has to work harder to rotate heavier wheels.
Ah I see, would it be better to just put 15" rims on?
Why would a 17" fit only fit if you lower it? Wouldn't you have less room? The fenders make sense though.Current:
Past:
Instagram: @CB7Nub
Originally posted by CB7Nub View PostAh I see, would it be better to just put 15" rims on?
15"s are typically lighter, but the same size as OEM. Most people prefer 16"s, as they are a good mix of size and performance.
I heard if you add a big size rim you speedometer doesn't read properly anymore.
For example if it says 100 kph you would be going only 96.6 kph or something.
If I put 16's and lower it would it fit right? What would you guys recommend for width?Current:
Past:
Instagram: @CB7Nub
Ah, would you know how much stock rims weight?
I'm looking on Tire Rack (lol yes I'm that noob) for that size, what would be a good place/brand to buy from?Current:
Past:
Instagram: @CB7Nub
Originally posted by H22WAGON93 View PostI have 18s with no rub. It all depends on your offset and width of the tire. Im runnin 215-35-18
so it depends on the size/offset/tires/ex...
93 Accord LX Sedan (sold)
Originally posted by Joshs92ex View Post205/55-R16 will be closest to stock size.
Per the Miata Tire Size Calculator, as well as the concept of +1 Tire Size determination
http://www.miata.net/garage/tirecalc.html
You'd have the following sizes to stay within OEM specifications
185/70-14 - Stock OEM DX/LX coupe and sedan tire size
195/60-15 - Stock OEM LX Wagon / EX / EX Wagon / 10th Anniv / SE tire size
205/50-16 - +1 over OEM 15" Size
215/40-15 - +2 over OEM 15" Size
Personally I went with a 215/45-17 tire, because I had a milder drop and wanted to close up the tire to fender gap.
Has anyone weighed a stock OEM alloy combination? Honestly, there are lightweight 17" rims out there that are going to be a performance increase.
Don't forget that you're adding wheel width, which will benefit handling, as well as a lower profile sidewall, which should go a ways towards reducing sidewall flex and firming up handling.
Originally posted by 91blkcoupe View PostGo with 17's they look the best in my opinion. if your tires are larger then stock your speedo will read slower then you are actually going. Use the miata tire size calculator to figure out your speedo readings.
Also you you mean 215/40-17 not 15?Current:
Past:
Instagram: @CB7Nub
Originally posted by CB7Nub View PostWill it read slower if I only get wider tires? Anything bigger would change it?
Ah nice do you have any problems with 215/45-17? How does the ride change? Thanks a lot for the guide.
I had Neuspeed Sport/KYB AGX on my car, and a hard right hand corner with someone in the back seat caused a very minor rub on the fender lip. I never had that problem when I didn't have someone in the car.
The only difference I noticed in the ride was that the tires were more likely to follow the ruts in the road.
Had I had the chance to spec out tires again, I wouldn't have changed anything. My speedometer was always ~2 mph off, so honestly when I changed tire sizes, I was always within that range. If I was slightly lower, I might have been more likely to pick up the 215/40-17 tire. The difference was 0.25" of fender to tire spacing.
Is there a way to fix the speedo if you change the wheel size?
I don't want any rub if possible.Current:
Past:
Instagram: @CB7Nub
