Replacing rear seatbelts on 1993 cb7
    Would like some info on replacing the rear, drivers side seat/shoulder belt. Has anybody done this on their own, or did they have the dealership do it? Should I buy a seat belt assembly from...say...JC Whitney or stick with a genuine Honda part. Obviously the importance is huge, due to the life that might be saved in an accident.
    Thanks in advance for the answers. Later Days....
    Freddy
    I believe our Honda belts have lifetime warranty and get replaced for free.. Contact your honda dealer.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      It should not be hard.
      I removed mine and there are just two bolts holding them in.
      I don't know where you would get a replacement other then honda or a junk yard, but just take off that back trim piece and unscrew the two bolts put the new one in, tighten the bolts back up, i believe they torque specs are listed in most manuals and you are set.
      Good luck, but it should not be hard.
      201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
        honda has lifetime seatbelt warranty...if it's worn let the dealership do it for you for free
        ____
          they def have a lifetime warranty, so just drop it off at a honda dealership....
          But if you want to do it yourself or change colors, like I did when I swapped my belts out for some black ones, then there are 3 bolts
          - the shoulder belts are bolted in with 2 bolts behind the rear pillar, you have to take the platic pillar covers off and the bolts are easily accesible. These two bolts hold the entire wind up and locking mechanism of a seatblet into the frame
          - the other bolt is simply an anchor bolt under the rear seats boltd to the floor, take the rear seats out and you cant miss it
          "Cars to me are meant, above all else, to be driven no matter what is done to them..."
          - RJ de Vera
            Is that for real? thats the first time i ever heard about that. The driver belt in mt cb does not go back in place which often gets jammed between the door. Would that count as a need for replacement?
            93 Accord SE
            02 Highlander Limited
              Seat Belt Answer
              Hey Bro's
              THANKS A HEAP for the FYI on the seatbelt. I 'll call my local Honda tommorow, at I'll let you all know the results from a dealer replaced presepctive!
              Later Days,
              Freddy
                my buddy got his Honda seat belt fix at Honda dealer for free.
                MY MEMBER'S RIDE TREAD: http://www.cb7tuner.com/vbb/showthread.php?t=118186
                  yup...had them do mine...it was working just was worn a bit
                  I wouldn't change the color...might somehow void the warranty. I know plenty of us have r&r'd the belts ourselves doing whatever things...but changing the color MIGHT not be a good idea. And since they have the color code on the door you couldn't say you swapped the interior
                  ____
