how wide?
    how wide?
    how wide of a rim can i fit on my car without rolling the inner fender? i will be doing a 1.75 drop with camber correction all around in the spring, so i would like to get a nice rim and rubber setup to compliment the cars new stance. still debating with keeping it lite with 15's or hittin the middle with 16's or just be show with 17's. but will most likely be 15. also what offset can I do 40 is stock i do believe?
    Thanks
    Lane
    1992 Accord EX-R 4 door Cobalt blue on blue 5 speed, friggin love this car.
    Performance mods: AEM short ram intake, Progress rear sway bar, and Apexi WSII cat back, skunk 2 wieghted knob, yeamans short throw. exedy oem style clutch pkg with a F1 racing 12lb flywheel, TASauto braided SS clutch line.
    Sound mods: Hertz space 6 1/2 speakers and tweets with a Audison Srx 2 amp, Focal 11" sub in a Focal ported box, Kenwood D-class amp, Audison cap and a Kenwood KDC891.
    nothing?
      Yeah nothing with the setup your talkin bout. My CB is dropped over 3" with 17's and 40 series tires and I didn't have to roll nothing. As a matter of fact it doesn't even rub. I had 18's at one point and I did have to roll the rear wheel well but it was all good.
        kool, but also im taling width, like can i do a 15x7.5 without rubbing?
          this is a good question. looking foward to a good answer to.
            I think with a wheel that small it would depend in the tire width, not just the offset and depth.
            I am new to the cb7 so I honestly dont know.
            The sky is always bluer at the top of the windshield.
              depends on the offset of the wheels you get.
                Exactly. I wrote an offset guide for 02 lancers on evom.net, so I know a little bit.
                It all depends on:
                Wheel size
                Tire size
                Wheel width
                Wheel offset
                They all have to come together just right to look good.
                  im not sure what offset i want, 40 i know is a safe bet
                    Well then you might not be able to go too wide with a 40.
                    If you know the offset that will come super close to the fender then all you have to do after that is find out how far you can come on the inside of the wheel well without hitting the strut/springs or other suspension parts.
                    I wish I knew more about this car so I could tell you. If you limit the offset to 40 then your wheel width will be smaller that the max. I know that for sure.
                      what say a 25 offset?
                        they'll rub
                        Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
                        -(B-Pillar Bar Originator)-
                          http://www.cb7tuner.com/vbb/showthread.php?t=36678 Its all there, everything you wanna know
                          Click ---->***More Parts and Stuff***<---- Click
