Rear seat removeing questions
    I am trying to remove my rear seats, I am only doing this so I can pull the carpet it out and clean it. Anyways I checked out some of the other threads but confused were the bolts are. can someone take a shot of there back seat and make marks were the bolts are and such.
    "Real intelligence is like a river; the deeper it is, the less noise it makes.”
    Click Me
    http://www.cb7tuner.com/vbb/showthre...ving+back+seat
    That's a thread on stripping the trunk and back seat, scroll thru the pictures and you'll find the bolts for removing the back seat
      I read that thread earlier and still didn't help, thank you thou.
      Click Me
        to get the carpet out you only need to remove the bottom part that you acually sit on, it should be in the middle i believe on the back side pull the seat(the bottom part where it meets the back part) back and you will see one bolt, unscrew it, pull the seat up like you are openning a treasure chest, once the seat is straight up, pull the seat up toward the headliner, to un hook the front part and you're done.
          That one bolt is near the middle seat belt.
          Couldn't take a better shot.
          I don't know if you need to remove the back part so it's easier to pull out the seat. Here's a pic where the 2 bolts per side are located (mine's only got one). You need to remove the corner pads first to be able to see it.
          Hope that helps.
            that helps a lot thank you
            Click Me
              if you look behind the carpet on e back of the seat you will see the bolts.
                Thank you found it and its already installed again.
                Click Me
                  that's nice
                    Just alittle off topic, but i didnt want to start a new thread.... What are some upgraded seats for the rear? Ive seen a lot of front seats done but nothing w/ the rears.
                      Find an accord with leather, or I think the 5 gen bolt in with minor modification.
                      Click Me
                        rear seat from the 94 or 96 Acura RL. Perfect fit
