Seatbelt Swap?
    Originally posted by Dajap View Post
    I have blue manual seat belts for a sedan (Front) if you are interested. I bought them from a member on here and they sent me sedan instead of Coupe's....
    so you have to have the retractor out of a coupe to put in a coupe.. i got a manual belt out of a 92-93 4 door wagon. will this not fit/ work correctly in my coupe????
    One step @ a time
      inb4 more useless posts
      90-91 USDM coupes / sedans have automatic seatbelts
      91 wagons had manual seatbelts
      92-93 USDM cars have manual seatbelts
      90-93 everywhere but the US had manual seatbelts
      ANYWAYS...
      Do you have a coupe or sedan? Coupe and sedan seatbelts are different, sedan seatbelts are height adjustable where as coupes are not.
      I have never done the swap before or even taken a look behind the pillar before to see if the mount point is even there. If you were going to do the swap you would need a new B pillar headliner trim piece and B pillar cover / rear cover in a coupe
      I believe the lower mount point exists already for the seatbelt but again i don't know about the upper one, you're going to have to look.
      For the buckles you are going to be fine, you can bolt the automatic seatbelt buckle from your seat and install a normal manual buckle without any problems.
        ANYWAYS...
        i own a 90' coupe. i have a manual belt out of a cb7 wagon along with the height adjustment. i kknow im suposed to make a bracket to fit in the pocket. but these items should work right
        One step @ a time
          The last person I know did this had to weld the top part because there was no were to bolt it up when going from auto to manual.
          Sold to:
          GunRunner,mtnickel,SanJoCaF22DrAcc,sikz6,daovangph otos,megarock15,
          Purchased From :cb95spd,"sleepin"
            ok i would basicly weld a strip of 18 guage then tap and dye a bolt into it...
            One step @ a time
              i was that person
                Originally posted by tommi View Post
                i was that person
                well since u were that guy. do u have any advice for what u went through doing this.
                One step @ a time
