Need Help With H3 Bulbs!!!
    So I just put in my JDM CC2 one piece headlights today...they use an H3 foglight. Same thing my USDM headlights used. Only thing is, the wire coming off of the JDM bulb is different than the USDM bulb!! All I can find at the store are the H3 bulbs with a SPADE connector on the end. These have a ROUND POINTY connector on the end...I don't know what you'd call it! Spades will NOT fit in the JDM wiring harness. Ebay doesn't have anything except the spades.
    The bulbs look to be original...they are Stanley bulbs. 35watt...USDM H3 is 55watt...that's all I can find.
    VIP Status.
    Here's a picture of the bulb and the plug on the end....never seen this kind before. Like I said, it's a 35watt Stanley bulb, and I'm pretty sure every JDM CC2 headlight has this type of bulb........I cannot, for the life of me, find that type of bulb anywhere (store or online)
    The bulb is in a metal holder...that's why it looks a bit weird. It's an H3, I'm pretty sure....looks just like my USDM H3 bulb but the glass part is just a little bit smaller. Maybe because it's 35w compared to 55w
    VIP Status.
      Nevermind...I rewired the fog lights. I cut off half of the wire to the bulb above and put a female spade connector on the end of it. Plugged in that pointed pin connected into the headlight harness, then plugged a normal H3 bulb with spade connector into the pigtail I made...
      Put the light in, turned it on and BINGO, worked....
      VIP Status.
        no problem. glad we could help
        you'll love my nuts!
