Where is the car most likely to have rust spots?
    I've seen some nasty rust hiding under the side skirts.
    The rear quarters are by far the most common, though. 90% or more of the CB7s in the NorthEast have rust there. I've had mine repaired twice, and it's coming back a third time.
      ya the rear quarter panals are natorious for rust on our cb's...other than that your probably good
      92 4 Dr Ex-sold/91 civic hatch(bad head)/93 civic vx
        bottom of doors... bad design allows water to sit inbetween the two sheets that make up the door. problem usually only if drain holes are plugged.
        RIP
        Bought from : LosiRacer2, h22anow
          1.along the top of the front wind sheld
          2.behind the sunroof
          3.on the sides of the wagons rear doors
          4.on the trunk hinge area
          93 Accord LX Sedan (sold)
            Originally posted by eastern_ethics
            took off interior in trunk looked under wheel well and didnt find anything...i know the first owner kept it in a garage and only put 98,xxx on it then i bought it off the second owner with 110,xxx and now it has 117,xxx
            then thats a nice clean ride my car when i first got it had 98,xxx miles the old man had it garage kept im the second owner now it has 113,xxx miles datz not bad i had my car for about 3 yrs now at the end of this month and it has no rust spots thank god... take good care of it..
            http://profile.myspace.com/index.cfm...ndid=107733305
              chek the rim around the trunk and the area along the base of the back windshield, but really if the quarter panels are good then you should be clear all around.
                paint
                idk if this is off topic but do u guys recommen geting it primered n paint or jst repaint it, i plan on geting the same color on the cb.
                  Having own several rusty ones before getting sick of them and getting one from Florida i can tell that the main rust area would be your quarter panels. Other than that, the trunk lid often has a lot. Check near the license plate lights, wing holes and even between the headlights. I would also make sure my floor is nice and clean before worrying about the body itself. Also check around your windshield, fenders and chassis behind them. Do not neglect anything. Rust is like cancel. Can be healed if spotted early but hard when it has spread.
                  NEW MYRIDE THREAD
                  PARTS 4 SALE
                    if you did any body work than primer that area...but if you sand down your paint well its actully a good surface to paint on
                      Originally posted by Joshs92ex View Post
                      Rear quarter panel is the most common.
                      But I have a little bit of rust beside my rear window molding.
                      most I have seen has rust spots on rear quarter panel.
                        make sure after its painted all the seals are on correctly or water will sit where it shouldnt and your car will be rusted in a year or 2
