Getting Headlight Out Problem
    Ok i searched and read all the Diy's for taking the front bumper off but I'm still having problems i got the 4 bolts out from behind the blinkers and all the ones from under the bumper and now im stuck i took my battery out and couldn't find any bolts down there so now im stuck this is my first Honda so I'm trying to figure stuff out any help would be appreciated, If it helps it's a 92' LX Sedan
    http://www.cb7tuner.com/vbb/showthre...ght=Blackhouse
    The first couple steps should help you with what your looking for..
    Originally posted by djcaz_aom
    1. Remove the side marker retaining screw. Pull out the marker and unplug the bulb connector.
    2. Remove the grill. It is held in place by five screws along the top.
    3. One is hidden in front of the latch
    4. Use a flat-head screwdriver to push down on the retaining clips that attach the grill to the bumper (one on each end, looking from the front), and remove the grill.
    5. Remove the two bumper retaining nuts (one on the left, one on the right) located behind the headlights, on top of the frame.
    6. Remove the two plastic retaining clips from the underside of the bumper.
    7. Remove the left and right bumper turn signals.
    8. Remove the four bumper retaining bolts (two on each side) located just behind the turn signal recesses. Lift the bumper, then slide it forward, and remove it. Set it down some place soft, as not to scratch it up.
    9. Remove the five headlight mounting bolts. Two are on the radiator support;
    10. One on the side;
    11. And two below the headlight.
      thanks, i finally found this bolt i took me awhile i was looking in the wrong spot now that i know where its at i feel like a dumbass cause it was in plain sight lol
        you don't need to remove the sidemarkers to remove the headlights but you do need to remove the bumper blinker lights. There should be two bolts in the engine bay, 2 phillips screws on EACH side near the edge of the bumper near the fender well, 2 bolts after you remove the bumper blinker lights on EACH side inside the bumper....will need some kind of extension to access these... and then 2 more splash guard plastic phillips screws. So 12 screws total to remove the bumper, not counting the 2 bumper blinker light phillips head screws.
          woo finally got it off, thanks for the help guys
