Rust Removal on Both Rear Quarter Panels?
    A little bit of help?
    Also, if you look in the second picture, some of the door jam is missing (rusted away) I'm thinking gorilla hair?
    Also, a bit off topic, I'm looking for some new headlights... And good (cheap) ones?
    gorilla hair, kitty hair, fiberglass. i would not recommend as it will come back most of the time.. i would go get patch pieces and weld them in.
    (129)Transactions and counting
      i have alil bit of rust starting can i sand that down and pray it dont go threw the panels?
      [IMG]http://cdn0.youplusplus.com/bs/small.84960.jpg[/IMG short ram,wires.plugs,header
        I think I can help
        First find the exact spot where its getting the moisture..(i dont know where it is on mine) Rust is cancer... If you dont treat the whole thing it will come back. You can go to your local auto store pick up a can of rust converter.That shit is great!!!! Cut out the rust. get a patch piece .. When you cut out the rust make clean cuts for easy replacement. After you cut out, sand with 80grit paper. Spray converter on inside of the area. Weld new piece in, clean up welds , sand new piece, start useing body filler.. I prefer a fiberglass filler (Marglass), sand ,Come back with a plastic filler(bondo or better), sand, Prime... I use 2 primers. A self etching, and a filler primer.... Good luck any questions lemme know
