SO.CAL Lounge/Postwhore Thread *real lexus pg 356*
    Originally posted by lummieCB7 View Post
    i'll bust out my 7 year old XPress to run with you guys.
    That's who had these RC's. I thought Joesue was the one that had said he had some. My bad.
    Mini Mini meet at the memorial day weekend meet!
      well, they say us asians look alike. LOL.
        You guys should check this out this year R&R Sample Sale:
        http://losangeles.craigslist.org/wst...133267226.html
        I got couple of jeans for a dirt cheap price.
        Hi
          yall bitches better bring that at the meet so we can have some action going on.
          might need to place bets as well...
          So SIIC...
          SoCal OG bitches...
            Pac Man Wins!
              played with this car yesterday.. anyone lookin to buy a good condition kidney.. lmk..
              Renntech supercharged.. 600+WHP
                you're telling me your bro just got one? or did u?
                  i wish.. neither.. i just got the opportunity to play with it.. that's why i'm selling my kidney..
                    love the rear of those things--very classy!
                    who wants a slammed arcadia green on itrs for 900?
                    http://orangecounty.craigslist.org/cto/1155767035.html
                      wilson, isn't that person a member on here?
                      or the OP is using someone else pic?
                      Cappuccino CB7 Member #4
                      FoDough fo moreho
                      [FuNKiE FrEsH]
                        no clue, nothing comes to mind.
                          I clearly remember seeing a pic of that car on here a while back.
                          oh well.
                          FoDough fo moreho
                          [FuNKiE FrEsH]
                            got a headache today diagnosing my own car. basically at 5000 rpm and on, the car will bog really bad like if it was running too lean or too rich. changed my plugs because they were corroded bad, did my cap and rotor, coil, and igniter and still nothing. put timing at 14 degrees and pinching off the fuel pressure regulator vacuum hose making the car run rich. and still nothing.
                            finally, I remembered that the wire from the coil to the igniter was really loose. so I crimped the connector tighter, and installed everything, and my car runs beautiful now. I have to say, with the h22 plenum and t body installed, it really makes a big difference.
                              it sounds nicer and has a little pep :P. Are you running the IAB and pt6?
                              I had to put my pt3 back in because the (3)pt6s I have like to throw oxygen sensor codes, pt3 stock ecu doesnt throw any and runs fine. This is after swapping out 3 good working o2 sensors. Car runs fine without operating iabs and revs nicer on WOT. :]
                                still using the iab's with pt6. the iab's are hooked up with the box. so it is controlled by the ecu. and yes, it does run a lot stronger. on a rolling start against my coworker's LS 5 speed from 50 mph, I took him till 95 mph, then he finally started creeping on my side. I was like wtf, my car is an auto. LOL. so when we got back to work, I clowned on him the whole day.
