prelude vtec master cylinder will work if you have abs, prelude is a 1 in. versus a 15/16 on the accord
So.Cal Mechanics Thread
Failed emissions at BAR test
I can't really figure it out. I just replaced the old CAT for a new magnaflow one last week. The engine was plenty warm for the test. Maybe the new CAT is a POS?
All sparkplugs/wires etc etc were replaced when I did the swap a year ago.
So the 25mph test was a pass.
The 15mph failed in HC and NO. HC was 172, max being 116. NO was 1222! max being 791.
Visually everything passed except the JDM p13. The tech said I have to get the USDM p13, and that it "would make a big difference" in emissions.
But he also said there were several reasons it may have failed, but "I can't tell you any of them"
This was at Chaffee college. Anyhow, I'm going to take a look at my sparkplugs, adjust the valves, clean the EGR ports, get a usdm P13 or maybe borrow one. Maybe get a bigger 3-way CAT.
I might need your help Jesus
Originally posted by 4CYLPOWER92I can't really figure it out. I just replaced the old CAT for a new magnaflow one last week. The engine was plenty warm for the test. Maybe the new CAT is a POS?
I might need your help JesusHeader Whorage and Official Part out sale.
Official Garage Sale Thread
http://jdmconcepts.com/ Head porting specialist..
Originally posted by jhondayaajI would def. look into a new o2 sensor from the dealer. not auto zone.
updated 3/7/2009=best ET to date: 14.2 (no NOS)
Originally posted by cb7Xtremehey joesue....your AT P13 is a POS.....i put my POS ecu back in there and my car idle good and no more check engine light....but ima through it in the cb and see wat happens...will keep you update....The beginning of a new era............................
Originally posted by optimusprimeDon't bring up BAR with craig...I passed in only 2 passes and he had to go back a few times. I got lucky $50 cat and a jdm p13 or what i thought was jdm. Oh well. good luck on bar.
Originally posted by bmxicansdI would clean my egr ports, change my oil before i you take it again, new spark plugs and make sure your cat is Hot before you take it in.. Did u turn your car off during the inspection? If so the catalytic converter will cool down within ten or so minutes.. Depending on what catalytic converter you purchased, be aware they don't work as well as a OEM one.. It also could be your O2 sensor.
The cat is a cheepo $70 magnaflow new from ebay.
Originally posted by blackcb7interesting kane, i can let you borrow my usdm p13 if you want. we can trade for a few days. anyway you have pm
Originally posted by ghost2.2id go to southwestern college in san diego to get it done. most of the sd guys bar'd their car there even with the jdm p13. the guy is pretty chill about too and says he hates cops because they dont know shit about smog and visuals. plus he did give craig his nick name "beefy" craig and jaime had to do it 2twice.
Anyhow my spark plugs look good, but my EGR was caked with carbon buildup. It wasn't completely choking the egr valve but it was getting there.Last edited by 4CYLPOWER92; 01-04-2008, 02:25 PM.
