So.Cal Mechanics Thread
    it may be the motor on its way out kane
    Members Ride
      Yeah, I was kinda thinking that too. Anyways it would be hard to test it since it only happens sporadic. I'm avoiding using that window for now since it would suck to park and not be able to put it back up. Time for a trip to the junk yard.
      My swap thread
      Main relay proplems?--DIY
        check the connectors as well to make sure they are making good contact, since this is not always happening it may be a loose connection.
        Members Ride
          I'd say bad motor.
            take your door panel off, when it happens again take a 12volt battery to the motor and see what happens. my passenger rear does that but in my case the switch is bad
            FA1
            355
              Originally posted by cb9tuner
              same here dude i still have a code 12, Im thinkin the only other option is clean my intake manifold ie.. egr ports or change my ecu
              what egr are you running? Accord or Prelude?
              Header Whorage and Official Part out sale.
              Official Garage Sale Thread
              http://jdmconcepts.com/ Head porting specialist..
                the accord one, just after I replaced the entire egr system it worked fine for like 2 weeks then all of a sudden it just boggs and cel came on , the onlt thing I can think of is to clean the egr ports, or the ecu
                  do you have the jdm or usdm intake manifold??
                    jdm
                      jdm
                      can you drill out the egr ports?? aren't they welded??
                        im going to remove the im this weekend and clean everything
                          kool. hope everything works out. what is your car doing anyways?? maybe I can take a look at it. what tune up have you done to it lately?? valve adj., what spark plugs, what gas?? what ign. timing is it set at??
                            it boggs in the morning and when i go 75-100 throttle, from a stop, and cel 12, everything is new tune up wise time was dead on when I put the motor in as of what I remember,have not done a valve adj. since I dont here any abnormal nosies, 91 , or 101 race gas (when I have extra cash)
                              no abnormal noise could mean tight valves. you should do a valve adj. at least you would get that out of the way. code 12 is egr??
                                Any of you San Diego guys have the phone number to the smog refs at Southwestern College???
                                My swap thread
