So.Cal Mechanics Thread
    I've seen old gas become like gum and clog up everything in the tank and pick up lines. But that was a few years old gas. 6 months should be alright.
    My swap thread
    Main relay proplems?--DIY
      Originally posted by GHOST 2.2
      most likely ill be driving to the hospital right after....
      I wanna get high too. so I'll join you.
        lol you know what my brothers car still has gas in it haha and its almost full too it looks like ima be getting free gas hopefully im still alive to enjoy it
        CLICK ON SIG FOR MEMBERS RIDE
        "2SIIC"
        Authentic Jerseys for sale
          blah check engine light came back on
          code 1, 43.
          need to double check wiring; right now it's running towards the intake manifold and drops under neath it to the bunge. Long suggested zip tieing it somewhere higher so its not resting on the engine?
            i have noticed after people have splice into the o2 sensor wiring, most of the time they will keep getting a cel for it, not sure if the connections are bad or if it just messes up the o2 sensor for some reason.
            i would solder the connections instead wilson, and heatshrink them, and try again, if not them a new o2 might be need
            Members Ride
              bleh, rechecked my wiring, it's fine. I think it's because one particular wire needs special care. The white live wire for the o2 sensor has dual wires that are insulated from each other one copper that's insulated with silver strands. I think I need to isolate each strand w/ it's own wire and hopefully it'll solve my o2 cel problems; going to also solder all the connections. If this doesnt work, going to change out the o2 with one of davids lol
              oh yea i'm getting 260miles a tank instead of my usual 300.
              that's 18.5mpg instead of my usual 22mpg.
              damn o2 sensor making me run riiiiiiich.
                If you hook me up with your flushmount, I'll drive over to your house, fix the o2 problem, and give your car a nice tune up.
                  hey guys i have a smog question. how can i get CO down. my NOX is fine but he said im getting too much gas. i took out the fmu to reduce fuel pressure. should i clean the egr valve and ports.
                  contact info
                  (562) 324-3639 chan mao
                    i had high co, needed new cat, if its real high it could be a weak ignition system
                    FA1
                    355
                      ic thank for your in put i think the culprit is o2 sensor and spark plug and the gap of it. its at .23 i belive
                      contact info
                        cat, conv. it will help out a lot.
                          Need a good Tune UP! Anybody, interested?!?!
                          Hello fellows, I live in the Palm Springs, right outside of the Inland Empire, still Riverside County. Anyways, I got a 90' EX 5spd Coupe, and i need a tune up. Anybody down for a half Saturday job?? I have a erratic idle issue, but if you've been around our CB7's this is nothing new. I need someone who is very knowledgeable and has the skills to get errrr done! I would purchase anything that needs to get replaced. I am looking for a hook up price, for there service of course. We can work out payment if its cash, or something i have you might need. Like i said, i got issues with my car now, and need to fix them quicker then what it would take me to get it done. Willing to drive to your spot, and get it done there.
                            blackcb7, jesus will take care of you
                            w00t, and socal keeps getting bigger.
                            whats your name?
                              I would recommend Jesus or Joesue.. I had Joesue check my oil, i mean change my oil pan gasket/oil pan and his work is top Notch.. Joesue might be the best choice since he is in Banning/beaumont.
                              Header Whorage and Official Part out sale.
                              Official Garage Sale Thread
                              http://jdmconcepts.com/ Head porting specialist..
                                thanks fellows, my name is Juan, can you please give me Jesues or Joesue screename here????? in this forum, since i do not know really anybody here personally. Been up in this forum for like 2 years, but, i come around here and there, i gotta meet all the peeps in the so-cal, hopefully there is some meet, and my ride is all tuned up, thanxs
