No Brake Light Action
    like i said, i have zero brake light action, and cannot figure out what in the hell is going on. i've checked the interior fues box. nothing labled "brake lights". checked the engine "fues box". it has a spot that says "horn/stop". the fues is good, horn works. cannot figure this out. and it needs to be fixed due to the fact of the meet this sunday. cannot roll using "hand gestures". any ideas?
    try checking your brake light switch and the brake light sensors and maybe bulbs??
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      Check all light ext/int fuses...check all connections of the wires and check the grounds...only thing I can think of is maybe sensors...but i suck at electrical man.
      When it rains it pours I guess.....main relays for the both of us going out and now your brakes....plus I didn't pass emissions today...fuck
      ________
      Bondage Female
      無限WESTCOAST FUKINWITCHU ACCORD4THGEN 1990 CB7 Coupe無限
        checked the plug in hooked up to the brake pedal assy. it was fine, and checked contact points w/test light. it was fine. checked the bulbs in the rear. they were all dead, not just blown, but completly fried n melted. bought new ones, and re-hooked them back up. everything is fine. but makes me wonder where the enormous power surge came from to cause the "melt down". but atleast they work now.
          Thats not good they were all melted and fried like that....you could end up with a fire...but least its fixed for now.....if it goes out again ya got a problem...good luck C money
          ________
          Side effects of wellbutrin
            this is what i think happend. i am no longer runing a "in line fuse" for my sound system. instead im running a 1 farad cap. you still need to run a circut breaker, but i have not gotten one yet. so i had to move the amp around, nothing got discombobulated, as far as i could tell. but,,,,, im guessing that by moving the amp around to remove the sub, its fried, that some how, it caused some sort of "power surge". and that is where it had the problem. but now the cruise control dont work, so i have some figuring to do. the cruise fuse is good, but now there is no power at its fuse slot under the dash. soooo, i junked something up. gotta figure it out now...............
