1998 Crv Iac
    1998 Crv Iac
    I have taken off twice and clean out my IAC Valve and My RPMS is jumping around. I tried to adjust the screw but cannot get my RMP to 600RPM. I did unplug my IAC Valve and Purg canister and did nothing for me. Im I missing something in the procedure or do I need a new IAC Valve? Help help.
    Anyone, help help!
      Can you please describe exacting what's going on? Is your idle higher than 600 and you can't get them down to 600? If so you probably have a vacuum leak.
        Well, I seafoam it, clean out the intake & hit every possible port available. Clean out my IAC Valve from carbon build up, also clean out FIT from carbon build up and screwed down the wax thingy. I double check everything up till now.
        I disconnect the IAC Valve and the Evap Purg Control Solenoid Valve, the lowest I can get the RPM'S to go down at 1100 & the idle screw wont go any lower. Just cant get the base idle to stay!
        Once I hook up everything up, RPM'S shoot up to 1700 and surges erratically to 2500 and my cell light comes on and & keep getting 0505 & 0505pd. Don't know what the pd stands for?
        Something is not right. I was checking the ports on the intake, bottom port when finger plug the engine speed does drop, but the upper port when finger plug, the engine shut off.
        That's where I am at this moment
          All of that sounds like a vacuum leak to me.
            Im open for that possible notion. How do I go about detecting a vacuum leak?
            Thanks
              This place crap out on me. Anyways, I double check everything and I have the same enchilada, cant set my RPM. The top port on the intake shut off my engine, is that related to the issue Im dealing with? Gonna swap out the IAC this weekend, but Im open to other new ideas.
              Thanks
                I still think of a possible vac leak. Take it to a shop and have them smoke test the engine. it will leak out of every spot there is a leak. TRUST ME the money spent will help so much. And it only takes 20 minutes to do.
                On a side note, I think I have swaybar endlinks for the front and rear of that car. They were very expensive because they were moog brands. My buddy sold the crv before I got to it, do you want it? Id sell it for a fair price. Im local as well.
                Retro!
                Hater
                  Nailed it. Swap out the IAC Valve. My old one got stuck open, I guess there is a small diaphragm in it, and it was shot up, saw the pieces flying around when I push compress air in it.
                  accordztech, I might be interested, give me a working number. Im in Davis.
                    My dummas didn't think of that...guess I was tired lol. Ill PM you
                    Retro!
                    Hater
                      Was the CEL for the IAC by any chance?
                      My 5.7 LS1 Holden Ute
                        yeah, cell light did go on, but reset it after swapping out iac.
