I have taken off twice and clean out my IAC Valve and My RPMS is jumping around. I tried to adjust the screw but cannot get my RMP to 600RPM. I did unplug my IAC Valve and Purg canister and did nothing for me. Im I missing something in the procedure or do I need a new IAC Valve? Help help.
1998 Crv Iac
Well, I seafoam it, clean out the intake & hit every possible port available. Clean out my IAC Valve from carbon build up, also clean out FIT from carbon build up and screwed down the wax thingy. I double check everything up till now.
I disconnect the IAC Valve and the Evap Purg Control Solenoid Valve, the lowest I can get the RPM'S to go down at 1100 & the idle screw wont go any lower. Just cant get the base idle to stay!
Once I hook up everything up, RPM'S shoot up to 1700 and surges erratically to 2500 and my cell light comes on and & keep getting 0505 & 0505pd. Don't know what the pd stands for?
Something is not right. I was checking the ports on the intake, bottom port when finger plug the engine speed does drop, but the upper port when finger plug, the engine shut off.
That's where I am at this moment
I still think of a possible vac leak. Take it to a shop and have them smoke test the engine. it will leak out of every spot there is a leak. TRUST ME the money spent will help so much. And it only takes 20 minutes to do.
On a side note, I think I have swaybar endlinks for the front and rear of that car. They were very expensive because they were moog brands. My buddy sold the crv before I got to it, do you want it? Id sell it for a fair price. Im local as well.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
My dummas didn't think of that...guess I was tired lol. Ill PM youWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Was the CEL for the IAC by any chance?
My 5.7 LS1 Holden Ute
