it's been a while since i've given an update, i have an entire 1g engine, I kept the 1g cams, put 2g pistons and wrist pins on 1g big rods, bolted on some arp head studs and main studs, added the commetic head gasket, deleted the balance shaft, added a front facing oil filter housing, I've ordered my kiggley adapter kit for the 1g block to bolt to the 2g automatic tranny, as the 2g torque converter is bigger and it needed a spacer.
i have a valve cover off a hyundai that fits you wouldn't know the difference unless you were told, as they also built 6bolt blocks.
it's been sand blasted and primed,
things to do.
1.I have my flat tire off ready to have it patched.
2.need to get new drilled and slotted front and rear disk brake rotors and pads as mine are so rusted the car cannot move until this is done.
3.ngk bpr8es spark plugs, as they are 1 step colder plugs
4.35-38mm external wastegate flange,, then weld it to my o2 dump tube
5.valve cover gasket
6.rear main crank seal... i better do it now.
7.thermostat gasket.
8.new fuel injector o rings as the injectors are used.
9.oil pan gasket
10.egr block off plate
11.2g k&n air filter
12. oil filter
13. a new battery
14. intake manifold gasket,,, maybe a magnus thermoshield gasket
15. i need to solder the new flange for the bov to the alluminum piping
I am waiting on my 1g intake manifold and the larger 1g tb to arrive,
so the 2g intake and tb i painted are up for sale dirt cheap i don't need them.
i still might have to re-work my exhaust to match up to the new 20g turbo ohh and i will be running the gigantic ported sbr cast manifold as well, i haven't taken photos yet..
I haven't ever removed and awd engine before, from my research I'll have to disconect the transferr case, keep it level and then pull the engine and tranny all in one unfortunately,, if this is the case i am sure their will be a few more unforseen suprises that will need to be fixed or at least maintained.
things to do.
9.oil pan gasket
12. oil filter
13. a new battery
