Night Wolf : 2001 Chevrolet Silverado 1500 LT
    My Honda Element's Replacement Vehicle
    >>>MOTOR & GEARBOX<<<
    5.3L "Vortec 5300" LM7 V8 (285HP/325TQ)
    4spd Automatic Transmission
    2WD
    K&N Air Filter
    >>>EXTERIOR<<<
    Extended Cab
    Sunset Gold Metallic Paint
    30% Tints All Around
    Step Side Bed
    Class 4 Trailer Hitch
    Plastic Z71 Bed
    >>>INTERIOR<<<
    Tan Leather Interior
    Full Electric Seats
    >>>SUSPENSION/WHEELS/STEERING/BRAKES<<<
    OEM 18" Rims Off Newer Silverado
    >>>AUDIO/ELECTRONICS<<<
    Stock CD Player
    >>>STUFF IT ONCE HAD BUT NOW REMOVED<<<
    Old 16" Rims
    >>>NEAR FUTURE PLANS<<<
    Thinner Tires
    Brakes
    >>>FAR FUTURE PLANS<<<
    Darker Tints
    Shocks
    >>>MAINTENANCE WORK DONE<<<
    Wipers
    Oil Change
    Spark Plugs
    Radiator Cap
    Cabin Filter
    Heater Controls
    AC Vent Flap Actuator Motor
    Drivers Window Regulator
    Passenger Window Regulator
    Knock Sensors w/Harness
    New Headlights
    New Foglights
    93 Accord LX Sedan (sold)
    Needs more low! And more LS goodies.
    I'm in the process of swapping a 350 for an LM7 at school in an 89' Chevy 1500.
      Might just lower it in the future.
        good stuff, lower it with 22"s
          Might just lower it. Gotta see how low I can go without modding the rear frame.
          Update on the truck, both front window regulators went. The cable snapped on one, and the plastic gears on the other ones motor broke apart. I also found out the hard way, that because of the knock sensors location ,they can fill up with water. screwing then up. Now I gotta find a knock sensor kit for it. Plus the brake fluid level sensor is bad. Gotta see if I can bypass it.
            Don't know if you repaired the knock sensors yet, but put some RTV around the rubber seals when you put it together. Keeps the water out.
            Those bed sides crack quite easily, be careful with them.
            Otherwise looks good. Outside of the rust belt you should be able to get 400K+ miles out of one of these trucks besides the occasional transmission rebuild. Up here they rust BAD after 10-15 years.
            1992 Accord Wagon (RETIRED)
              I did it like that after putting in new sensors & harness. but now I got the codes again. gotta see whats up with that this weekend. got a few maintenance items to take care of too.
              and Ive seen some snowbirds try and sell those rusty ones here. for the price of rust free local ones. theyre nuts.
              btw, I did see that theyre plastic bed sides. one was repaired and has cracked again FTL. might go with a regular bed.
                Good. Stopping using the SIR for garbage runs lmao
                  But its fun to put it to work lol. anyhow, Ive given this truck to my dad. But I will still be fixing it up. New pics coming soon.
