She's rough on the outside but the motor is in good shape and the interior is very nice. I'll have more pics as I progress through this build. These photos are of the car right when I got it, no cleaning or anything. The car sat undriven about 6 months before purchase.
Modifications:
Powertrain
F22A1 SOHC
Cylinder Head
Stock
Air Induction System
H23 throttle body with 67mm bore by Maxbore
H23 plenum portmatched to throttle body by Maxbore
Blacktrax intake manifold spacer
F22A6 runners
EGR ports drilled & tapped, and pipe plugs put in
Bisimoto heat-shielding intake manifold gasket
IAB plate removed
Custom 3" intake with AEM dryflow filter
FTIV block-off
EGR valve block-off
Fuel System
AEM clear annodized billet fuel rail
Ignition & Engine Electronics
PT6 ECU
NGK Platinum plugs
NGK spark plug wires
Exhaust system
Cosmetics & Miscellaneous
ESP F22/H22 swap mounts, wrinkle black
Shaved valve cover
Neuspeed billet oil cap
MFactory magnetic oil and transmission drain plugs
AC deleted
PS deleted
CC deleted
Drivetrain
M2S4 H23 transmission
F1 Racing Stage 1 Clutch
CorSport USA Aluminum Shifter cable bushings
ChaseBays -3an ss clutch line
Suspension
Function & Form Type II Coilovers
Prothane front lower control arm inner bushings
Prothane front lower control arm outer bushings
Prothane front upper control arm bushings
Energy suspension front sway bar end links
Energy suspension front sway bar mounting bushings w/zerks
Moog front lower ball joints
Moog front upper ball joints
National front wheel bearings
Powdercoated front knuckles
Chassis
Non 4WS
Rebuilt steering rack
Moog inner tie rods
Off-brand outer tie rods (temporary)
ESP traction bar with front torque mount, wrinkle black
Brakes
Front 11.1" rotor conversion, drilled to 4x100
Prelude VTEC/Accord V6/ITR front calipers powdercoated wrinkle black
Techna-Fit SS brake lines, smoke color
ATE Super Blue racing brake fluid
Stoptech Street Performance brake pads
Shoes
ARP extended wheel studs
Muteki Super Tuner black open ended spline drive lug nuts
Drag DR-44 Silver w/machined lip 15x7 +40
> Dunlop Direzza DZ101 205/50/15
Electronics
Stock
Interior
Polished gauge cluster trim panel
Red and white LED dash conversion
Exterior
Not clean
Spoiler delete
Antenna delete
Future Plans:
Drive the shit out of it.
Modifications:
Powertrain
F22A1 SOHC
Cylinder Head
Stock
F22A6 runners
IAB plate removed
FTIV block-off
EGR valve block-off
Fuel System
PT6 ECU
NGK Platinum plugs
Exhaust system
Shaved valve cover
AC deleted
PS deleted
CC deleted
Drivetrain
Suspension
Chassis
Non 4WS
Moog inner tie rods
Brakes
Shoes
Electronics
Stock
Interior
Exterior
Not clean
Spoiler delete
Antenna delete
Future Plans:
