Originally posted by lil_dcb7
buddies is-300 1jz-gte motor swap 56k
why would you put a 2j head on a 1j bottom end? the heads are pretty similar, but the 1j head 'flows' better. its the 2j bottom end that gets you all the boost capability. more people are putting 1j top ends on the 2j bottom, in fact ive never heard or seen anyone put a 2j top end on a 1j bottom.
Originally posted by Dv8why would you put a 2j head on a 1j bottom end? the heads are pretty similar, but the 1j head 'flows' better. its the 2j bottom end that gets you all the boost capability. more people are putting 1j top ends on the 2j bottom, in fact ive never heard or seen anyone put a 2j top end on a 1j bottom.
That's the whole point to the "1.5JZ" swap
you take the 1Jz head and stick the 2JZ Bottom end...maybe I dont get your post, but I figured most people knew that already.14 Ford Focus ST - stock(ish) - E30 Tune + Green Filter =
IM puttin the 2jz head because there was a flow chart of both heads. The 2jz head outflowed the 1jz head. Yea I am putting the head on the block if funds allow me to if not I am just gonna leave it as is.
Originally posted by lil_dcb7if you have a pre 89 supra, make sure you swap out the controll arms(i believe it is) because they use some hydraulic motor mount or some shit.. If I remember correctly...
Come on homie! You have a Supra and you don't know This??
In order to install the 1JZ onto pre 91 MKIII you will need the cross member from the 91-92 or from the JDM MKIII Clip
T
95 Accord Wagon EX - Stock
