I Gotta Motor Question For My 87***
    ok ok ok i know this its 4th gen accords but i have a question for you people...not the 3geez group...
    ok i have a 1987 honda accord lx-i hatchback...
    its auto...
    I was wondering which swap you ppl would recommend me doing...its between a B-series(prolly gs-r) or the H-series(h22a)
    im lookin for the one with less hassel and lower cost to do
    ive heard that the mounts on a B-series are pretty much the same(i dont know if its true...)
    i've also heard that that its hard to find axles to go on a H-series swap to the (86-89) honda accord hubs...
    idk...i need some advice about this....im thinkin about keepin my hatch now...
    thanks
    -happyj
    I ♥/Miss My Coupe
    ur best bet would be to go 2 3geez.com. but i found out that it would be better 2 put a b20 or b18 in it. being that the H22 and H23 are 2 big. u could turbo the motor u got in it due 2 the fact that it has a cast iron block which is GREAT 4 boost
      i was thinkin the b18 myself...but it depends on how much modification there is the put it in...i know im goin to have to get a ecu, wire harness, and so on...i was just wonderin which motor you guys would suggest....any more feedback?
      I ♥/Miss My Coupe
        ur best bet would be a b20 swap. just make sure u hav the usual stuff like axls and so on. u should be ok. then if its not enough power still, trubo it.
          lol...i dont have enough money to import/buy a jdm b20...the lude and cr-v ones wont work in my car..., i think i would rather get what ever kinda motor my dad could get me...ive got $250 in my wallet and ima see what my dad could do...i could always get a motor with a good block and one with a good head a put the 2 together...but, idk...any more ideas
          I ♥/Miss My Coupe
            if he can put a b20 in, he can put any b-series, and why not just get a b18c? It's the best engine.
            -Jose
              i gotta question Jose, the b18c is the gs-r motor right?...
              I ♥/Miss My Coupe
                you need a mount kit for the B-series swap. they dont make them anymore. sadly, if you had searched, this HAS been covered here before. PM deev, he knows quite a bit about the 3rd gens.
                -Mark-
                CB7
                CD5
                  aight...sorry, didnt know it was already covered...
                  I ♥/Miss My Coupe
                    anymore comments from you ppl...?
                    I ♥/Miss My Coupe
                      ZC DOHC with turo. ZC are really cheap.
                      88-91 Si ZC 4G - EF 1595 9.6 : 1 129 @
                      6800 rpm 106 lb/ft @
                      5700 rpm JAPAN
                      (http://www.streettuners.com/curve/en...cs.html#accord)
                      http://www.homemadeturbo.com/turbo_projects/t25/
                      - Zipcreature
                      Awesome!
                      CB7. F22A. 5spd. CB7. Exedy. Chromoly. AEM. DCSports. Apexi. Progress Group. AGX. Suspension Techniques. Viberant. Goodridge. Facebook
                        i would never put a zc in a civic at all yes its cheap and a direct bolt up but it doesnt have the power of a b-series
                          im not talkin about a civic...im talkin about my 87 honda accord hatch
                          I ♥/Miss My Coupe
                            sorry i meant accord
                              well forget what every1 up here is sayin. try goin 2 3geez.com. they'll give u the info u need. better than others up here
