All I can say is
Honda Valkyrie Rune Specifications
Manufacturer: Honda
MSR: $24499
Model ID: Valkyrie Rune
Model Year: 2004
Type: Cruiser
Emissions: NA
Available Colors: Candy Black Cherry, Double Clear-Coat Black, Illusion Blue
Honda Valkyrie Rune Engine:
Engine Type: 1832cc liquid-cooled horizontally opposed six-cylinder
Bore and Stroke: 74.0mm x 71.0mm
Compression Ratio: 9.8:1
Valve Train: SOHC; two valves per cylinder
Carburetion: PGM-FI with automatic choke
Ignition: Computer-controlled digital with three-dimensional mapping
Honda Valkyrie Rune Drive Train:
Transmission: Five-speed
Final Drive: Shaft
Honda Valkyrie Rune Suspension:
Front Suspension: Trailing bottom link; 3.9-inch travel
Rear Suspension: Unit Pro-Link with single shock; 3.9-inch travel
Honda Valkyrie Rune Brakes:
Front Brakes: Dual full-floating 330mm discs with three-piston caliper
Rear Brake: Single 336mm disc with two-piston caliper
Front Tire: 150/60R-18 radial
Rear Tire: 180/55R-17 radial
Honda Valkyrie Rune Dimensions:
Rake: 0 degrees
Trail: NA
Wheelbase: 68.9 inches
Seat Height: 27.2 inches
Dry Weight: 794 pounds
Fuel Capacity: 6.1 gallons
