93 Honda Prelude?...
    Yeah, a buddy of mine I used to work with is selling a 93 Honda Prelude non-SI for $2800 with 130K miles. Here's a rundown:
    Pro's:
    1. 17" Katana Rims with tires 95% tread
    2. Auto Start
    3. Alarm
    4. No body damage
    5. Paint (white) is relatively sound
    Con's:
    1. CV Axles shot, but will fix for an extra $100
    2. ABS light on
    I'm not sure how much these cars usually run for but I know they sell pretty well. There's nothing mechanically wrong other then what's listed and the previous owner since it was first bought was a female (whether that makes a difference). Please let me know what you guys think so I can make a offer based on it's actual worth. Thanks in advance...
    That's cheap for a 'lude...although the ABS light scares me.
      He says it brakes normally but I personally do not know the effects or the reasons as to why this ABS light remains on. Not sure what it means either but I hope it's not something that could be more serious. Thanks for the reply...
        9 times out of ten its a sensor issue. you will still brake normally, just abs wont kick in. maybe its not such a bad thing?
        Finally Up and Running. Numbers to Follow. Check my MR
          Sensor issue? If that's the case then what is the ballpark value to fix something of this nature? Thanks...
            lol, i wouldnt fix it. if its the abs motor itself that is bad, id say fuck it. but if u want, pull the code and look it up and then u could go from there. anywhere from 20-300 dollars ranging from an axle sensor, to an abs motor.
              abs light on = abs wont activate. other then that it will brake fine. it could very well be something simple like a wheel speed sensor or it could be something important and cost like a grand. non-si still leaves us with 2 choices, the s with the f22, or the vtec with the h22. if its a vtec then thats a very good deal, however Im assuming its an s, in which case thats not bad at all but nothing spectacular.
              HSHO #3
                Yeah 6/10 cars I know have their ABS lights on. One of the cars belongs to a mechanic. If its not that important to him, then I don't think its a big deal. I would buy it
                  Yeah, it's the F22 engine and not the Vtec, althought I figure it's still a decent deal considering some of the same cars in worse condition bone stock sell for more. This one has some extras that make it worth it in my opinion...
                    that is def a great deal on a lude the abs light on could be a few things on my car i popped the fuse for it so it wasnt a big deal but if it is the fuse u have to reset the ecu after you change it. as for cv joints $100 to fix is an awesome deal def go with that. if plus its a 93 so its obd1 which means more fun
                    my car is slow
                    B00$teD h23 500+hp of pure power mmm
                      My friend is going to go ahead and get this car. I saw it for the first time the other day and it looks awesome. Thanks for the feedback guys...
                        Just FYI, the ABS light on Honda ABS systems up to about 97 is generally caused by leaky seals and a low fluid level. They tend to leak very slowly, so you won't really notice any fluid around. Depending on who built the ABS system, it may or may not be easy to fix. Check some of the other Honda forums as this is a known issue on Honda's ABS systems. In the case of the difficult ABS fix, it is a $2.00 seal that goes bad. The expensive part is that you have to completely disassemble the ABS unit to change it.
                          I'll be sure to take note of that. Thanks...
                            the abs light may be b/c of the cv joints. isn't there a ring or something on the axels that are a part of the speed sensor? cause the half shafts are different between abs and non abs cars. and personally, i'd be glad that the abs doesnt work.
                            1992 Prelude S w/swapped H22A
                              IT's all good. The car ended up having a cracked block. Oh well, good thing my friend didn't buy it...
