If the 1st gen CLs have the same tranmission as the 5th gen V6 Accords (95-97), I do not recall those being an issue. If it has the same transmission as the 6th gen V6 Accords ('98-'02), those are known to have issues as noted by many others (but not as much of an issue if fluids changes are done exactly when required if not even earlier). Owequitit can tell you (and has previously noted in detail about this matter).
Btw, the 2nd gen TLs ('00-03 only-- the '99 had a 4 speed transmission still) also were known to have transmissions problems which appear as common as the 6th gen Accords. (same body). I have a '98 V6 TL (first gen '96-'98) which is not known to have abnormal issues.
