So I have a camry and everything runs fine. The only problem is that it's getting 20mpg when it should be getting 30ish mpg. I've done the usual maintenance items such as rotor, cap, wires, plugs, fuel filter, and air filter. The throttle body has been cleaned and the tires have been inflated to the recommended psi. I've even tried running injector cleaner through the fuel system, but nothing has improved.
What could be the problem? The car has 70k miles and is in pretty top notch condition. Any suggestions are welcome.
