Maples boost project update.. How ya been people..
you need to step up to 577 srt4 injectors, and def get off emanage. evans tuning gave my brother a good deal on the KPro for like 1200, which was the Kpro, the gear, a 4 bar map sensor, and electronic boost solenoid. he got his ecu from a M/T CRV for 40 bux. look into them.
Yeah i have RSX type S injectors.. also I think im gonna go with AEM becuase i can use it with anycar.
Plus Kpro I can get for 1,050 from RPM racing in NY
this is a reliable DD is what im heading for. I get my AEM wideband tommrow So ill be installing that on thursday.
Emanage is just temp... and I dont want a bigger turbo.. becuase then ill have bigger problems. Plus IDK if a bigger one would even fit? What would be an upgrade from a T25 that will be a direct fit?
The AEM is only for the Base RSX and the Civic SI with the crappy K20a3 in it. Also the civics. So when you say it is for "any car" it isnt. Its also rediculously more expensive than the KPro, by about 4-500 bux. Both are standalones.
Also when I say 1200 like I said, thats for the KPro, the Cam Gear, the 4Bar Map, and teh Elec Boost solenoid. All things that make tuning and having the more options better for your car.
I know you have RSX-S injectors, but i think those are only good up to 5ish lbs before they are maxed out.
And bigger turbos, look at Andy's build, Clints build, Steve's build, and my brother build all on 7thgenhonda. My brother is using a .48 hot and .70 cold Garrett T3/60. Andy is using a GT30R, Clint is using something similar, and Steve I believe is using a 62-1. So there is plenty of space. Andy also is running a 4" intake for his compressor side.
Anyone ever notice how EVERY SINGLE thread ever posted by maple turns into something else? lol! props on boosting the car nontheless
Its because of his reputation
Maple - What are you final goals HP wise?
And have you looked into any other tuning options - Crome, Hondata, Even Chessboxers Haltech system?
Look into all of them and see what best suits you
