K series, chain jump
    I have a Civic Type-R in at work and the timing chain is one tooth out on the intake cam. Has anyone seen this before?
    It seems physically impossible for a chain to "jump" a tooth without damage, but I have a Civic at work which it seems this has happened to.
    The car won't idle and won't hit VTEC.
    Just wondering if anyone has seen this before, and the possible cause.
    I am still yet to check the intake cam adjuster for being possibly seized, though that can't/shouldn't allow the chain to be out by 1 tooth due to the direct relation to the exhaust cam/crankshaft gear on the chain.
    Confused as hell
    My 5.7 LS1 Holden Ute
    I've seen a few chains jump in the K20a in the CRV/Stream.
    Dont know how it happened though.
    CTR, FD2R?
    Click sig to view MR thread
    Links to other rides:
    Honda Accord Euro-R
    Honda Odyssey Absolute
    Honda City I-DSi
    Honda Stream
      DIY gone wrong?
      To-Do List for Today
      Be Awesome
        Originally posted by wafflefries View Post
        DIY gone wrong?
        Motor hasn't been touched by anyone other than the honda assembly plant.
        I did a little research, and it seems that some of the K20 high reving engines get this problem, especially if upgraded cams and valve springs are fitted.
        Apparently its the tensioner that is at fault.
        If I set everything at tdc the chain won't go on the intake cam gear, An if the chain is on the crank the cam is about 3/4 of a tooth out . . . Stretched chain I'm guessing.
          tensioners FTL
          Push rod chains ftw
          wat?
            so you need a new chain?
            93 Accord LX Sedan (sold)
              Well to be on the safe side we're replacing:
              Chain, Chain guides, Tensioner, VTC Cam actuator.
              What are pushrod chains?
                whats a VTC Cam actuator
                  So simple, no tensioner
                  wat?
                    Its basically an adjustable camgear, but it can be controlled by the ecu.
                    Hmmm that looks better.
                    And also has twin chain, and much better teeth.
                      Yeah I read about this in one of my electronic courses. It's able to Retard or Advance the timing of the motor.
                      Pretty neat stuff as well.
                      Henry R
                      Koni/Neuspeed
                      1992 Accord LX R.I.P
                      1993 Accord EX OG since 'o3
                      Legend FSM
                        btw take some pics of the cars you have there at work
                          i believe this is only on a few of the i-vtec motors correct?
                          Formerly 91AccordExR33
                          11.68 @ 127mph
                          417whp/375wtq
                          Sold: 8/2016
                            It appears the timing jump is only on the high revving K20 series, but also interestingly this motor isn't listed as "i-vtec" only vtec.
                            This is what caused some confusion - We don't sell the Type R Civic new in NZ, which means we don't have the manual for it.
                            So i had to look through 5 different shop manuals (Integra, and integra type R, Civic - which is the R series and K series engine, and Civic type R supplement only, which diddnt contain ALL the info I needed) engine's, to come to a conclusion on the initial problem which was - No VTEC and won't Idle, with a code indicating the Cams out of phase.
                            So realistically i'm still only Guessing what the problem/initial cause is/was.
                            When i reset the chain the other day the intake cam was out 3/4 of a tooth which leads me to beleive the chain is stretched but it still seems
                              CTR, FD2R?
                              K20 CRV?? We get the K24 CRV. Is your model 4WD?
