Car about to hit 200K What can I expect?
    Originally posted by SN2BH22CB7
    you only need 2 cans of seafoam...
    1 for the gas tank...and 1 for the split...( intake 1/2 )..( oil 1/2 )
    being I do both cars...yes...it does get expensive...but I do this..to KEEP both CBs in good running order!
    you dont need to use two cans...just one. And it's not recommended at every oil change, more like every 3 or 4, using it too much breaks down seals.
    and you certaintly dont need to buy cheap oil after you run it.
    It's the consensus on honda-tech that you just put 1/3 in gas, 1/3 in brake booster, 1/3 in crank case.
    Let it sit for 5minutes, and beat the shit out of the car, to get it to smoke, and do an oil change.
    dont know where you're getting your info from.
      I have heard from a honda mechanic locally that has years of experience said, that a little bit of carbon on seals ensures a tight seal on cars with over 170k.
      Like ikayto said, putting seafoam in the oil everytime you do an oil change is detrimental to the seals.
