Throttle Bodies.
    Throttle Bodies.
    I heard that F, H, and s2k throttle bodies are interchangable within each other. if so is there any better one to use? i have a h22 auto. and the bracket that holds the kickdown cable keeps coming off and has sheared off bolts....
    Cali.Dumps.Harder.
    Type R throttle bodies also fit i believe, but don't quote me on that. i believe they are a little bigger than prelude throttle bodies.
    Members Ride
      hm.? any proof? i might try one if i kno it can be done...
      Cali.Dumps.Harder.
        i run an s2000 throttle on mine.
        www.850fab.com
        IG - @850Fab
        FB - @850Fabrication
          F/H throttle bodies are not interchangeable, unless you're speaking of the DOHC F22B, which is essentially an H23.
            what tb is interchangable on a h22?
            Cali.Dumps.Harder.
              b16, b18, b18c, f20c, h23....i'm sure there are more
              www.850fab.com
              IG - @850Fab
                so you can put the h22 plenum on the f22a6 runners...that gets you the h22 tb on the f22 (but not really)
                can you put the s2k or type r tb on the f22? Or do they only fit the h22 plenum?
                course boring the tb out would prolly be eaiser then finding an s2k or h22/h23 tb...imo
                ____
                  just for future reference f22b2 sohc non vtec fits on h22a
                    The throttle body or the entire intake manifold?
                    I'd suppose they have the same tb as the f22b1, which is the same as the f22a. I would think so anyways.
                      Throttle body.. I have it on my h22a since my tps was smashed and didn't want to deal with swapping the sensor itself.
                        No you can only put an H22, S2k (AP1 style, non-drive-by-wire), and type r TB on either a H23 or H22 plenum. The F22 Plenum has a different bolt pattern vs the H22/23 plenum.
