anybody know how to adjust/fix these things? or where to obtain them? the spring inside the valve is off-kilter, and i belive is causing my idle to bouce. any help?
jdm h22 fast idle valves?
Same as the f22 valve, its not meant to be serviced, but screwing it in can settle the idle
http://media.honda.co.uk/car/owner/m.../400/6-206.pdf
remove the cap and run the engine cold, place your finger on the valve seat, and you should feel air flow.
allow the engine to reach operating temp, and feel again. The valve should have closed, and you should feel no suction. If you do, the FITV should be replaced. In a pinch, you can screw it down.
http://www.honda-tech.com/zerothread?id=1003988
http://www.superhonda.com/forum/show....php?p=2894634
http://www.cb7tuner.com/vbb/showthre...ight=fitv+idle
The valve adjustment is the same as the F. The only problem is that the valve is under the throttle body. Its easier to pull off the tb and adjust it. And yea wrong section.
