Visual Basic help
    Visual Basic help
    I have a program all i need to do is fix the last part, I keep getting an end of statment error and cant figure out how to fix it, and snytax error *
    Private Sub CalcButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles CalcButton.Click
    'Select Case True
    'This adds
    Dim strChoice As String
    strChoice = OperationGroupBox.Text
    Select Case True
    'AnswerLabel.Text = Val(UnitsTextBox.Text) * 10
    Case RetailerRadio.Checked
    if val(UnitsTextBox.text < 3 Then
    UnitsTextBox.Text = 5 * Val(9) Then
    else if
    val(UnitsTextBox.text) > 8 then
    *14
    Elseif
    val (UnitsTextBox.text) > 9 then
    * 12
    Case WholesalerRadio.Checked
    If Val(UnitsTextBox.Text) < 4 Then
    * 10
    elseif
    val(UnitsTextBox.text) >5 then
    * 9
    End If
    End Select
    End Sub
    Click Me
    'Select Case True
    'This adds
    Select Case True
    Code:
    You have too many then's and not enough if's.
    Change that around and see if it fixes it.
      Aside from that, your missing a closing ')' on that same line.
      try and use the [ code ] [ /code ] tags next time. it makes it easier to read.
        Still not getting it I cut out a lot of the code if i can get one peice to work here is what I have done
        Code:
                'Select Case True
                'This adds
                Select Case True
                        If AnswerLabel.Text = Val(UnitsTextBox.Text) < 3 Then *15
                End Select
            End Sub
        End Class
        Click Me
          can you post the exact compiler errors.
          OT: God i hate Visual Basic.
            I get a snytax error If AnswerLabel.Text = Val(UnitsTextBox.Text) < 3 Then *15 right at the time symbol
            Click Me
              Need to move that down to the next line to do your logic operations. Nothing should follow the "Then"
              i.e.
              AnswerLabel.Text = Val(UnitsTextBox.Text) *15 (or whatever operation you are doing).
              else if
              blah blah blah
