office a/c
    office a/c
    What can I do to make the A/C to blow coolder air.our current ac seems to work olnv for 2hrs then it sucks,
    is there a way I can ad freon?
    Im going to tint the windows hope it helps
    1991 Sedan
    click image for MRT
    -Nava
    Is it a window A/C unit? or central air unit?
    window air: clean the filter and fins behind the plastic cover. I don't think you can refill most window units. you can always buy a new one for cheap.
    read this bit of info on how to choose a new one if the above fails to help:
    http://www.lowes.com/lowes/lkn?actio...nditioner.html
    central air: change filter to a decent one and get a pro to come in to take a good look at the unit. chances are the fins are clogged with dust. See if a refill is in order.
      tint wont help alone.. make sure it actually blocks the heat .. they sell that type of window at .. home depot
        well its a window unit,the windows are double glass.Thanxs for the link im gonna check it out
        1991 Sedan
        click image for MRT
        -Nava
          The solution is to call the facilities people and have them fix it.
