Does any one know how you add your URL to search engines
    the 192.168.2.10 is your LAN IP, the address your router assigned to your computer via DHCP, I assume the IP you gave us, 67.70.161.33 is your WAN IP, which is given by your Service providers router(s). Do you use a static IP for this website? Using cable, my IP is dynamic, ever-changing. They are leased and reassigned after about 6 hours. I believe to host from a personal computer, you need a static IP. I tried to ftp the WAN IP you gave, but got no response, I'll get on linux the try some nmap'ping, please don't accuse me of hacking, a firewall may set off warnings when I nmap!
      I come to you from a live knoppix dvd , here's what I got. I'll see you back on the windows side!
      knoppix@0[knoppix]$ nmap -sS -O 67.70.161.33
      You requested a scan type which requires r00t privileges, and you do not have them.
      QUITTING!
      knoppix@0[knoppix]$ su root
      root@0[knoppix]# nmap -sS -O 67.70.161.33
      Starting nmap 3.81 ( http://www.insecure.org/nmap/ ) at 2005-06-30 00:32 EDT
      Warning: OS detection will be MUCH less reliable because we did not find at least 1 open and 1 closed TCP port
      All 1663 scanned ports on Toronto-HSE-ppp3896300.sympatico.ca (67.70.161.33) are: filtered
      Too many fingerprints match this host to give specific OS details
      Nmap finished: 1 IP address (1 host up) scanned in 148.438 seconds
      root@0[knoppix]# nmap -v -v -sR -sV -sU 67.70.161.33
      Starting nmap 3.81 ( http://www.insecure.org/nmap/ ) at 2005-06-30 00:43 EDT
      Note: Host seems down. If it is really up, but blocking our ping probes, try -P0
      Nmap finished: 1 IP address (0 hosts up) scanned in 2.056 seconds
      Raw packets sent: 4 (136B) | Rcvd: 0 (0B)
      root@0[knoppix]# nmap -v -v -sP 67.70.161.33
      Starting nmap 3.81 ( http://www.insecure.org/nmap/ ) at 2005-06-30 00:44 EDT
      Host 67.70.161.33 appears to be down.
      Nmap finished: 1 IP address (0 hosts up) scanned in 2.050 seconds
      root@0[knoppix]# nmap -v -v -P0 67.70.161.33
      Starting nmap 3.81 ( http://www.insecure.org/nmap/ ) at 2005-06-30 00:36 EDT
      Initiating SYN Stealth Scan against Toronto-HSE-ppp3896300.sympatico.ca (67.70.161.33) [1663 ports] at 00:36
      SYN Stealth Scan Timing: About 9.02% done; ETC: 00:41 (0:05:03 remaining)
      The SYN Stealth Scan took 335.58s to scan 1663 total ports.
      Host Toronto-HSE-ppp3896300.sympatico.ca (67.70.161.33) appears to be up ... good.
      Nmap finished: 1 IP address (1 host up) scanned in 335.603 seconds
      Raw packets sent: 3326 (133KB) | Rcvd: 0 (0B)
      root@0[knoppix]#
      Notes, information gathered says Toronto, "ppp" I believe is DSL, sympatico (ISP?) ".ca"=canada, all ports are
      filtered, router(s) are blocking all traffic
        yeah .. i give up.. I dont have a static ip... im pretty shure you can only get one for a buisness account, and bell sympatico tells me they basicly dont troublesoot the router unless i cannot connect ... so all the features are on it are useless unless you know the modem..
        if i want the company that made the router to troubleshoot they charge 45 dollars for each issue... (no thanks)
        im gonna wait awhile and maby get a cheap web host when i get cashflow again.
        thanks for all the help btw
