Let's see those tool boxes!
    Originally posted by bassrock234 View Post
    they are mostly an aircraft thing. But I've seen them on cars before, Usually downpipes on turbo cars. Do you guys drill the bolt heads yourself? I've seen jigs to make it nice and easy. But I wonder about the strength of the bolt head after being drilled like that.
    you can drill the bolt but it is not FAA approved. at least as far as i know. all the nuts and bolts on a plane are FAA approved. and if it is ment to be wired it will have a hole in it. the holes are not that big. most are .032 which is the most common wire type.
    as you can see here the holes do not compromise the integrity of the bolt. it is just ment to keep it from backing out
    some of the bolts on a plane can be very expensive. some can go up to 50k just for one. the ones i deal with at school range from $100 to $20 a bolt. still quite expensive.
    Here is a pic of a job i did to an oil press relief valve when i first got the pliers. they can be a bit hard to use at first if your used to doing it by hand. notice how it is pulling it to tighten it. you dont want it going the other way in flight
    visit vgruk
      Hot damn that's an expensive bolt! My friend's dad is a head painter for gulfstream, but I've never seen much as to how assembly goes.
      I wish I could trade my heart for an extra liver, just so I can drink more and care less.
        "My FOR SALE thread - Click here"
        MEMBERS RIDE
        99 SILVERADO
        WHEEL FLIP
            Got around to organizing my box.
            Top, full of random shit and a light I made from a prosport gauge
            First Drawer, screwdrivers, rivet gun, tubing cutters, pitch gauges and feeler gauges
            Second drawer, standard and metric ratcheting wrenches, line wrenches
            Third drawer, 3/8ths metric stuff, deep and shallow, impact, ratchets
            Fourth Drawer, Pliers, oil filter wrenches, mini screw drivers and picks
            Fifth drawer, air tools, gauge, die grinder, tq stick, 1/2in impact
            Bottom, all sorts of random shit, everything 1/2in, brake caliper kit, funnels, battery chargers, misc wrenches and sockets
            and my streamlight on the side
              bumping because I finally got my new box set up
                ^^^ I like those Husky boxes.
                I have several boxes. The grey one I use regularly as the others contain mostly specialty tools. I threw in some other pics as well. Car lift, oxy/acetylene torch, gas mig, arc welder, hydraulic press, large vise, parts wash, drill press, what ever else you see.
                As you can tell I'm cramped for space. The 3rd week of October I will have a new 21'x36' 3 bay metal building built which has been a long time coming as I cannot take the constant clutter any longer.
