I have a couple set of gearwrench flex heads and love them.
Ratcheting Wrenches
Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
I have 6 sets of them, 2 that you flip over to either tighten or loosen. 2 with the switch to tighten or loosen, and 2 set of flex heads. I put the 4 foot breaker bar on them quit a bit, espically pulling upper ball joints. The flex heads are great to get into places, but kind of awkward to use because as you pull/push they want to go side to side
Oh, I have gear wrenche brand, and use them daily, if I can't get the impact in there, I use the gear wrench.Last edited by Soufkackicustom; 11-25-2012, 05:17 PM.
I've had a set for years at work, I wouldn't work without them.
Only broken one, and that was for that same reason as above - using an impact on the other side.
Best thing is the ability to add these:
Makes it way slimmer than a regular rachet.
My 5.7 LS1 Holden Ute
Originally posted by Accrdwgnguy View PostI wouldn't think they could hold up to 600-1000 ftlbs of torque. Just use a normal closed end wrench.
I picked up a 20pc set of Gearwrench (Metric and SAE) for $50 from Sears for the black friday special. I think the Gearwrench ones have less movement needed (5 degrees) to ratchet, so the really tight spaces they beat the others.
Originally posted by BurtonRiderT6 View PostI would like to meet the guy who can put that much torque on a hand tool.
Read the quotes.
I do have a set of SAE and Metric flex head gear wrenches. They are a quality product, had them for 2 years and haven't broken one yet. Had a couple freeze up but I was able to unfreeze them easily
Originally posted by BurtonRiderT6 View PostI would like to meet the guy who can put that much torque on a hand tool.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I received a set of these last holiday season:
[url=http://25.media.tumblr.com/tumblr_m049pczpDX1rq68fdo1_1280.jpg][/img]
I asked for them because I had no 17mm wrench for the transmission fill plug, and there was no room for a ratchet to get enough leverage, and an adjustable wrench keeps rounding the plug. I used the ratcheting side to break the plug (which was on there tight!) and it held fine. The only thing I wish they had was either an angle, or a swivel to allow angling, so I can reach tighter places. But, usually in those tight places, there is no room to ratchet anyway.
