CarFax?
    CarFax?
    Does anyone have access to CarFax (either personal or through a dealer)?
    Trying to help out a friend and figure out what trim level this Nissan Pathfinder is.
    Vin # below
    Code:
    jn8ar05y9ww268595
    Can't figure out if it's an LE, SE, or XE.
    If anyone is familiar with the differences in trim levels, let me know
    Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
    this is what i found.
    http://www.nissanhelp.com/diy/common/nissan_vin.php
    doesn't really say what trim.
    does this help
    Free Car VIN Number - VIN Decoder for Nissan Autos & Vehicles.
    Look up vehicle identification numbers for all car makes and vehicle models, by year, from Nissan. Decode VIN number information on the following makes and models:Nissan 200SX, Nissan 240SX, Nissan 300ZX, Nissan 350Z, Nissan 370Z, Nissan Altima, Nissan Altima Hybrid, Nissan Armada, Nissan Axxess, Nissan Cube, Nissan Frontier, Nissan GT-R, Nissan Maxima, Nissan Murano, Nissan NISMO 370Z, Nissan NX, Nissan Pathfinder, Nissan Pulsar, Nissan Quest, Nissan Rogue, Nissan Sentra, Nissan Stanza, Nissan Titan, Nissan Truck, Nissan Van, Nissan Versa, Nissan Xterra
    ** Please scroll down to see a complete VIN number decoding data chart. Vin Decoder **
    What is a VIN Number?
    A VIN number is a 17 character alpha/numeric serial number unique to each vehicle, by manufacturer, make, model and year. Each character in the VIN number can be decoded to determine where the car was built, what year, which automotive features are included and more. Together, all the VIN numbers create a history about your Nissan.
    Where To Find The Vehicle Identification Number Tag
    How to use this vehicle identification number information to decode your Nissan VIN number: First, either find your VIN number on your vehicle registration or car title or in vehicle maintenance records from your dealer. Additionally, you can find the VIN at various locations on your car. Frequently you can find your VIN number in one of the following locations: on the driver's side door jam (sometimes on the passenger's side), under the windshield on the driver's side, near the firewall of the vehicle or on the steering column. Other places to search for a vehicle identification number include various locations under the hood of your car.
    Now that you found your VIN Nissan number, you can start to decode your car, truck or automobile. The first character The first character indicates the country where the vehicle was manufactured. The United States has a VIN code of 1 or 4, while countries such as Japan (J) are designated with letters. To decode your VIN number, simply match your VIN characters to the chart below. Search first to find the model year for your car, then, in order to check VIN number to determine your car history details, match the corresponding position of your vehicle ID number to each of the fields below.
    Decode VIN Abbreviations
    Here are handy VIN abbreviations. In example, a 2dr, 4WD, conv, LE would convert to a two door, 4 wheel drive, convertible, limited edition. Some of the most common abbreviations: 2 Dr = Two Door | 4 Dr = 4 Door | 4WD = 4 Four Wheel Drive | AB = Air Bag | AT = Automatic Transmission | Auto = Automatic | AWD = All Wheel Drive | Cyl = Cylinder | Conv = Convertible | Cpe = Coupe | Dr = Door or Drive | FWD = Front Wheel Drive | HB = Hatchback | HP = Horsepower | HT = Hard Top | L = Litre | LE = Limited Edition | LWB = Long Wheel Base | MPH = Miles Per Hour | PU or P/U = Pickup | RWD = Rear Wheel Drive | SE = Special Edition | Sed = Sedan | Spd = Speed | Spt = Sport | ST = Standard Transmission | Std = Standard | w/ = with | w/o = with out
    Ride: 2002 Lexus IS300
      http://www.getvin.com/
      try that out
      wat?
        year 1998 Engine Type 3.3l V6 Ohv 12v
        Make Nissan Driveline 4wd
        Model Pathfinder Ground Clearance 7.50 In.
        Trim Level Le 4wd Front Brake Type Disc
        Manufactured In Japan Rear Brake Type Drum
        Body Style Sport Utility 4-dr Anti-brake System 4-wheel Abs
        Transmission 4-speed Automatic Overdrive
        Standard Seating 5
        Mpg Hwy 19 Miles/gallon Optional Seating No Data
        Mpg City 15 Miles/gallon Tires 235/70r15
        Dealer Invoice $29,580 Usd Wheelbase 106.30 In.
        Msrp $32,849 Usd Curb Weight
        Does This Match?
        source
        http://www.decodethis.com/Default.as...AR05Y9WW268595
          Thanks Chris, that worked and everything matches up.
            Heres what I got. I like how it says it was wrecked into a parked car.
            Your AutoCheck Vehicle History Report
            1998 Nissan Pathfinder LE / SE / XE
            Report Run Date: 2012-06-01 19:07:49.744 EDT
            Report Summary
            Class: SUV - Lower Mid Range
            Engine: 3.3L V6 EFI
            Country of Assembly: Japan
            Vehicle Age: 14 year(s)
            Calculated Owners: 4
            VIN: JN8AR05Y9WW268595
            Year: 1998
            Make: Nissan
            Model: Pathfinder LE / SE / XE
            Style/Body: SUV 4D
            This vehicle's AutoCheck Score
            The AutoCheck Score is a summary of your vehicle's history. It lets you compare similar vehicles with ease.
            About the AutoCheck Score
            This vehicle qualifies for Buyback Protection
            buyback
            Safeguard your investment with AutoCheck Buyback Protection. It reduces the risk in buying a used vehicle.
            About Buyback Protection
            AccidentCheck
            Reported accidents: 1
            Title and ProblemCheck
            Your vehicle checks out!
            OdometerCheck
            Last Reported Odometer Reading: 134,564
            Vehicle Use and EventCheck
            Specific vehicle use(s) or events reported
            View Full History
            AccidentCheck
            Not all accidents / issues are reported to AutoCheck.
            A problem has been found with this vehicle. Information Reported! AutoCheck shows accidents reported to AutoCheck for this 1998 Nissan Pathfinder LE / SE / XE (JN8AR05Y9WW268595). Below you will find the date and location reported for the accident. Not all accidents or damage events are reported to AutoCheck.
            Accidents Reported on This Vehicle
            Accident No. Reported Date Location
            1 12/07/2008 ID
            Reported accidents or damage events are a result of vehicle collisions or other non-collision incidents such as vandalism or theft. Not all accidents or damage events are reported to AutoCheck.
            checks_out Your Vehicle Checks Out! AutoCheck's database for this 1998 Nissan Pathfinder LE / SE / XE (JN8AR05Y9WW268595) shows no negative titles or other problems. When reported to AutoCheck, these events can indicate serious past damage or other significant problems, and disqualifies the vehicle for AutoCheck Buyback Protection. Check the Vehicle Use and EventCheck for reported accidents that can affect vehicle safety and value.
            0 Problem(s) Reported: 15 Title/Problem areas checked:
            image No abandoned title record
            image No damaged title or major damage incident record
            image No fire damaged title record
            image No grey market title record
            image No hail damage title record
            image No insurance loss title or probable total loss record
            image No junk or scrapped title record
            image No manufacturer buyback/lemon title record
            image No odometer problem title record
            image No rebuilt/rebuildable title record
            image No salvage title or salvage auction record
            image No water damaged title record
            image No NHTSA crash test record
            image No frame/unibody damage record
            image No recycling facility record
            OdometerCheck
            checks_out Your Vehicle Checks Out! AutoCheck examined the reported odometer readings reported to AutoCheck for this 1998 Nissan Pathfinder LE / SE / XE (JN8AR05Y9WW268595) and no indication of an odometer rollback or tampering was found. AutoCheck uses business rules to determine if reported odometer readings are significantly less than previously reported values. Not all reported odometer readings are used. Title and auction events also report odometer tampering or breakage.
            0 Problem(s) Reported: Mileage Date Reported
            image 4,084 11/16/1998
            image 19,500 11/12/1999
            image 27,388 11/10/2000
            image 59,996 05/30/2003
            image 77,000 05/27/2005
            image 80,189 10/18/2005
            image 89,981 07/29/2006
            image 100,327 06/11/2007
            image 116,980 01/30/2009
            image 134,564 07/30/2010
            image Information Reported! AutoCheck shows additional vehicle uses or events reported to AutoCheck for this 1998 Nissan Pathfinder LE / SE / XE (JN8AR05Y9WW268595). This includes reported vehicle uses such as rental or lease, and events such as whether the vehicle has been reported to have had a loan/lien or a duplicate title issued. Other events show if the vehicle has a reported accident and how many calculated accidents or if it has been reported stolen or repossessed. It is recommended to have pre-owned vehicles inspected by a third party prior to purchase.
            0 Event(s) Reported: 6 Vehicle uses checked:
            image No fleet, rental and/or lease use record
            image No taxi use record
            image No police use record
            image No government use record
            image No livery use record
            image No driver education record
            3 Event(s) Reported: 9 Vehicle events checked:
            image 1 Accident record(s) reported through accident data sources
            image No corrected title record
            image No duplicate title record
            image Emission/safety inspection record(s)
            image Loan/Lien record(s)
            image No fire damage incident record
            image No repossessed record
            image No theft record
            image No storm area registration/title record
            Full History
            Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
            Report Run Date 2012-06-01 19:07:49.744 EDT
            Vehicle: 1998 Nissan Pathfinder LE / SE / XE (JN8AR05Y9WW268595)
            Event date Location Odometer reading Data Source Details
            03/16/1998 ID
            Independent Source VEHICLE MANUFACTURED AND SHIPPED TO DEALER
            11/10/1998 BOISE, ID
            Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
            11/16/1998 BOISE, ID
            4,084
            Motor Vehicle Dept. TITLE (Lien Reported)
            07/21/1999 BOISE, ID
            11/12/1999 ID
            19,500
            State Agency PASSED EMISSION INSPECTION
            08/10/2000 BOISE, ID
            11/10/2000 ID
            27,388
            07/18/2002 EAGLE, ID
            08/14/2002 EAGLE, ID
            05/15/2003 EAGLE, ID
            05/30/2003 ID
            59,996
            08/14/2003 EAGLE, ID
            05/27/2005 ID
            77,000
            09/01/2005 EAGLE, ID
            10/18/2005 BOISE, ID
            80,189
            07/29/2006 ID
            89,981
            11/03/2006 BOISE, ID
            06/11/2007 ID
            100,327
            05/15/2008 ID
            11/03/2008 BOISE, ID
            12/07/2008 ID
            State Agency LEFT FRONT IMPACT WITH A PARKED VEHICLE (Case #:08C222560)
            01/26/2009 CALDWELL, ID
            Motor Vehicle Dept. EXCLUDED/EXEMPT
            01/30/2009 BOISE, ID
            116,980
            03/11/2009 CALDWELL, ID
            08/13/2009 CALDWELL, ID
            03/08/2010 BOISE, ID
            07/30/2010 ID
            134,564
            01/14/2011 BOISE, ID
            06/21/2011 BOISE, ID
            This Vehicle's Glossary
            Below are the specific definitions for events that appear in this vehicle's report.
            More information is available in the full AutoCheck glossary.
            Term Section Location Definition
            Loan/Lien Vehicle Use and EventCheck A loan/lien is the legal right to take and hold or sell the vehicle of a debtor as security or payment for a debt. Normally, a vehicle will have a lien due to a loan or unpaid repair bill against the vehicle. Check with the seller to ensure that the lien has been satisfied.
            Emission/Safety Inspection Vehicle Use and EventCheck An approved emission testing station has inspected the vehicle to measure the amount of pollutants the vehicle emits into the environment.
            Accident or Vehicle Damage Vehicle Use and EventCheck Reported accidents or damage events are a result of vehicle collisions or other non-collision incidents such as vandalism or theft. Not all accidents or damage events are reported to AutoCheck. Certain accident or damage events are reported by the source to have resulted in minor, moderate or severe damage to the vehicle, or the events are calculated by AutoCheck to have resulted in minor, moderate or severe damage based on the information reported. It is recommended to have pre-owned vehicles inspected by a third party prior to purchase.
              LOL yes SHE did a great job driving it...
