we are having a monsoon
now you get a taste of what we go through here often in FL
93 Accord LX Sedan (sold)
Originally posted by thepowderblue View Post
It will get a lot more fun when shit starts flooding and washing away.
Ok I'm sooo confused on what the winnie the poo is a monsoon?
Originally posted by deevergote.......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
It was just a REALLY big dust storm. No rain here, maybe in other parts like near Sky Harbor Airport but not in Chandler
member's ride thread
91 Accord SE 176k
Originally posted by turboAccordHSF View PostOk I'm sooo confused on what the winnie the poo is a monsoon?
It is the primary source of moisture in the SW US, and essentially, the southerly airflow brings warm, moist air off the Gulfs of Mexico and California, and when mixed with the other drier air in the region, and the intense convection caused by the intense summer heat, results in strong lifting forces. Since warm, moist air and strong lifting equal thunderstorms, we get them. They pretty much occur daily for most of the last half of the summer and sometimes into late September, depending on the year.
They will occur slightly earlier in the day in the higher elevation/colder regions, and later and more violently in the evenings, since there is more latent heat available to fuel them and stonger lifting mechanisms. Typically, in my region we get them about 2-3pm and the lower, hotter deserts get them around the time the sun goes down. The desert storms are later, but they are much stronger, and much more violent. These storms bring lots of flash flooding, high winds, dust and sandstorms and can be extremely violent. Sometimes if the conditions are right, we can get supercells (strongest type of thunderstorm), squall lines (long line of T-storms) or Mesoscale Convective complexes (a large ring of T-storms that keep regenerating). These storms are responsible for many of the large dry washes in the area, and some of the other geographical features. They are very breathtaking and awe inspriring and make some of the most beautiful lightening storms you will ever see, due to the high heat of the air that causes them. Unfortunately, they can also be very deadly if not respected due to the rapid, and severe flash flooding. Fields, washes and roads will literally go from bone dry to being under several feet of water in a matter of minutes. Also, since it is mountainous, once that water gets moving, it can do some serious damage as a result of velocity.
Often, people will assume that summer thunderstorms are all monsoons, but technically, if they airflow isn't from the south, they are not actually monsoons. The winds swung around late last week, and by this weekend, we were getting pretty widespread towering cumulus buildup (the stuff that eventually becomes T-storms), and then it started raining about 3 days ago. Usually, you can just about set your watch by them, as they often arrive within ~30 minutes of the same time everyday.
Luckily, we don't get too many supercells or tornados out of them due largely to our terrain features, which make it harder for them to get that severe like in the Midwest. Although, some of our larger ones in the lower deserts are really close.
We haven't really had a healthy monsoon in AZ for nearly 10 years. Hopefully, this year will be different. Our forests need the water. When I was younger it was very regular and predictable, although it does vary based on either El Nino or La Nina.Last edited by owequitit; 07-06-2011, 12:59 AM.
Where is all of the dirt coming from!
Normally the rain washes it away.
I opened the garage up and this is what I see
lx
My SE
A few rain drops
Uploaded with ImageShack.us
