Washing machine
    Washing machine
    Just got this washing machine for free. replaced the water pump cause it was leaking. now the spin cycle wont come on and it wont stop filling up. its to the top and it wont drain and the motor wont turn on. help?
    -Will
    lol your fucked.
    COUPE K24
      Originally posted by '93CB7Ex View Post
      lol your fucked.
      Since when did this turn into hondatech?
      -Will
        Water level switch.
        When people couldn't differentiate "your" and "you're".
          Originally posted by JoshM View Post
          Water level switch.
          Is there a way to drain it? or reset it? because its to the top and i found a plug for it so i put it in but it still wont drain. Its sorta a pressure switch.
          -Will
            Hmmm it is hard to tell without looking at it, but isn't there a drain plug around the back?
            What about where it normally drains from???!?!!
              Is your water pump electric or is connected to the drive motor?
                Also.....it would help if you posted the make/model...
                did you try Googling the product to find an owners manual?!?
                  kenmore 80 series super capacity
                  -Will
