Whats the best way to turn off an engine
    Without using the key?
    Go.
    MRT
    sneaky motherfucker
    Disconnect the battery?
    Or do you mean from inside the car?
    My FB Page - http://www.facebook.com/hellaflush3d
    My 3D Work --> http://samauripizzacats.deviantart.com/
      Don't?
        put metal wire in the starter and on ground terminal hahahahahha jk jk jk
          Pull the plug wires.
            Syphon enough gas out of the tank so the car will run out of gas
              dump the clutch in a gear without giving it gas.
                The car would not turn off....
                Pull the ignition fuse..
                  Clog the intake with somthing
                    Originally posted by fatboy1185 View Post
                    Push it into a lake.
                    Why not drive it into the lake?
                      Cover the exhaust or snuff out the intake. No risk of damage, and no more combustion.
                      "This truck is 100% sh*ts and giggles."
                      "Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
                      You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
                      Disregard females, acquire currency
                      BUS 62 AIN'T F'ING AROUND!
                        Why not lake it.
                        Past 1990 Accord EX Sedan
                        Past 1990 Accord LX Sedan
                        Past 1991 Accord LX Sedan
                        Past 1993 Accord LX Wagon
                        Current 1991 Accord EX Wagon
                          Buy a German engineered, Mexican built, vehicle and it will quit on you without using the key!
                          MR Thread
                          GhostAccord 2.4L Blog
                          by Chappy, on Flickr
                            pull the main relay
                            93 Accord LX Sedan (sold)
