poor design....
    poor design....
    So today I ventured off into the realm of starters. My starter motor has been on its last leg for a month now and i finally bought a new motor yesterday. Today, i figured it would only take a few hours to replace it. So as im removing everything to get to the motor i begin to realize the task is a bit more daunting than i would've imagined. So, i finally remove everything ... except for the final bolt that holds the motor to the engine block and i cant get it off... -_- Its in the worst possible position a bolt could ever be. Its sort of underneath the starter towards a labrynth of hoses and sharp metal objects near the rear of the engine bay. It seems as if they built it like that to purposely make you frustrated, its the most poor design ive seen lol. Everytime i try to remove it, it seems more and more likely that the bolt is welded on by some sort of super strength hulk-like rust. I'm currently soaking it in wd-40 and i will try tomorrow once again. If anyone knows of a simpler way to do this task please help lol =]
    These cars have the easiest start removal/install ever... Try a hard car like a v6 eclipse etc..
      I never had a problem with it.
      I even taught my ex how to do it. She installed a starter on my H22 in 5 minutes.
      The first time I did it, I removed my radiator fan for more clearance. That was more difficult than doing the starter itself.
        i 1/2 ratchet with extension(maybe a universal joint) and a cheater bar on the end of the ratchet
        it is very easy if you aren't using something like an open ended wrench
        ''COUPE''
        ''WAGON''
          Quit your bitching, like ChIoVnIdCa said, it one of the easiest.
          Try this.
          http://www.freeengineinfo.com/cadill...eplacement.htm
          wat?
            Having the wrong tools for the job will make ANY task you face in life hard.
            My 5.7 LS1 Holden Ute
              The 5 spd H/F starters are cake because they are right infront of the motor.
              I think he has an auto though, and they are a bitch to get to.
                Not really. If you got a decent set of tools its easy as well. 10minute job tops.
                wat?
                  If you think thats hard, try working on a Nissan. Honda is by far the simplest car Ive ever laid my hands on.
                  ----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
                  NE GUYS, Buy the last of my accord parts
                    Then you have never worked on a geo
                      True.
                      As far as Honda's go - The 5 cylinder is the hardest.
                        Try replacing a starter on a cadillac northstar V8 I bet you wouldnt complain about doing any other starters
                          comparison thread now? lol it's a simple task
                            use more leverage, try to get extensions and then a 24" breaker bar if that bolt is too tight.
                              finally got it off last night, what happened was the previous owner had stripped the bolt.... so when i was trying to remove it, there was no grip thus making any job a headache. And yes other starters are harder to remove and they would be 100x more difficult with stripped bolts.... guaranteed. But my thread wasn't about merely removing it, it was about the poorly designed (and stripped), oddly placed bolt that made it difficult to remove. But I'm glad its taken care of.
