wooden 240mph car
    wooden 240mph car
    all i can say is wow
    http://www.joeharmondesign.com/index.html
    Specs of the car.......
    LAYOUT
    Mid-engine, rear-drive
    CHASSIS
    Laminated wood veneer Monocoque
    BRAKES
    F 14.0in drilled, slotted, vented rotors with 6 piston calipers R 12.0in drilled, slotted, vented rotors
    WHEELS
    3 piece- forged rims, laminated wood center section
    F 19in X 10in
    R 20in X 13in
    TIRES
    Michelin Pilot Sport 2
    F 265/35ZR19
    R 335/30ZR20
    STEERING
    Sweet Mfg Integrated Servo 12:1 Rack and Pinion
    FRONT SUSPENSION
    Unequal length upper and lower laminated wood A-arms
    Transversely mounted laminated wood leaf spring
    Adjustable remote reservoir tube shocks
    Laminated wood anti-roll bar
    REAR SUSPENSION
    Laminatesd wood trailing arms
    ENGINE
    Aluminum block and heads
    32V DOHC reverse-flow cylinder heads
    4.6L displacement
    Twin Roots-type superchargers
    4 air-to-water intercoolers
    Projected 600 bhp
    DRIVETRAIN
    6 speed manual transaxle
    Getrag limited-slip differential
      you'll become a toothpick if you hit anything at 240mph.
        im not going to even think about driving a wooden car over 80. and this dude thinks its going to go 240? good luck, hope shit dont fall apart
        miss my turbo cb7
          Fucking AWESOME
          I would rock the shit outta that !
          Members Ride Thread - http://www.cb7tuner.com/vbb/showthread.php?t=121452
          Originally posted by slammed4thgen
          dustin, you are a dick!
          officially the lowest ive seen now
            Imagine how many splinters you'd get working on this thing.
            R.I.P. Veronica - JDM F20A swapped 2.0 Si wannabe.
              Just dont drive it in the rain....
              Originally posted by Jarrett
                look at the engine... the intake side is where the exhaust side would normally be.... interesting.
                "Tucking tires and wires."
                The Chronicles.
                  Hah the "Splinter". That shit looks siiick
                  life is good.
                    I remember seeing pics of the Splinter last year. The thing is just plain nuts. I wouldn't trust my life at 240 to wooden suspension components.
                      WING/MUFFLER
                      A twin-supercharged V8 makes a lot of horsepower. Along with this power comes a lot of heat. Wood isn't particularly fond of excessive heat, so we wanted to keep the engine heat off the wood as much as possible. In an attempt to quickly remove the heat from the engine bay, we decided to run the exhaust out of the top of the engine by reversing the flow of the cylinder heads. From there, we realized that we could also put the muffler and its heat outside by letting it serve double duty as the wing. Just don't lean on the wing after turning in hot laps; your arm might stick to it, and that just isn't cool.
                      To-Do List for Today
                      Be Awesome
                        I'd never own it, but the idea is amazing. +1 for creativity.
                        "This truck is 100% sh*ts and giggles."
                        "Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
                        You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
                        Disregard females, acquire currency
                        BUS 62 AIN'T F'ING AROUND!
