hey slateboy I know to everyone this must be offtopic but can you please show us how you custom installed your racing seats i have the tenzo rally and i would like to install them oplease thankyou.
Attn : slateboy
are you trying to install them using the stock mounts & sliders?
If you are... I can help with that...Last edited by ZigenBallZ; 01-08-2005, 02:37 PM.RIP Lifsatrip7
Who What Hunh? Yea, I gotta pull out my driver seat tomorrow to get some no-slip on the bolts and paint the rails. I'll take some pictures and draw up some schematics. The only problem I ran into with my setup, mind you is cheap, is there is limited rolling ability, but with trial and error, can set your seat to whatever initial position.
-Shale
Originally posted by h22sparkleyes thats what i plan on doing what do i need and how do i go about installing them please show me how im clueless in this area.
i have sparco brackets. just get some of these.
JDMED
buy my jdm part
http://www.cb7tuner.com/vbb/showthread.php?p=544951#post544951
The best way is to have a band saw, but an air powered cutting wheel will work. Everything off the original sliders, you'll see what I'm talking about, everthing is tack-welded in your original seat's setup, to a basic slider/bracket assebly. Leave the location that the buckle bolts to, that's important. Alright, now intstall the brackets back in the car, minus the seat. Measure from the center of one bracket, the width, to the center of the other bracket. Then measure the width, from one bolt hole on the bottom of the seats to the other bolt on the bottom of the seat. Subtract the difference to find out the total gap between the bolt holes and the brackets. Then divide by two to find the gap on either side. Then go to menards, get some welding steel. Cut it to this length, drill a hole to bolt your seat to on one side, and weld it to the bracket on the other side.
