would any1 be interested on a remote start diy
    Yeah, lets see the remote start DIY. I hope there'll be wiring diagrams and the like for it.
      Does anyone have a wiring diagram for the remote start? I have an auto so I don't have to bypass anything, just find the wires and ya know hook it up!
      Thanks
      Originally posted by cp[mike]
      oh well. its just a car, its not the end of the world.
        Thanks
        12volts: white + ignition harness
        Starter: black/white + ignition harness
        Ignition: black/yellow + ignition harness
        Accessory: yellow + ignition harness
        Power Lock: black/white - lower drivers kick
        Notes: The station wagon uses green/white for lock and yellow/white for unlock. These wires are found either in the drivers door harness or under the rear seat.
        Power Unlock: black/red - lower drivers kick
        Locate the large harness in the lower below the carpet in the drivers kick panel. Near the foot rest you will notice a piece of blue tape attached to the harness itself. Reach around to the underside of the blue tape to locate a 2 pin gray plug with the lock and unlock wires attached to the plug.
        Parking Lights: red/black + fuse box in dr. kick, there is also a male terminal in the fuse box itself.
        Door Trigger: black/white - brown plug left of column
        Trunk/Hatch Pin green/black - green plug left of column
        Tachometer: blue AC distributor
        Brake Wire: green/white + at brake switch
        Horn Trigger: lt. green/blue - column or horn relay
        Notes: High-current ground. Use a relay when interfacing with this circuit.
