I copied this from a wiring site I use for work. I see a LOT of posts asking for wire colors for alarms, door locks, mainly to wire a radio. Well here it is, the last time I'm posting it. Sticky it, learn it, save it, copy it, do whatever with it.
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) GRAY/WHITE
LR Speaker (-) BLUE/YELLOW
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Amp Location IF BOSE AT EACH SPK
Radio Security YES
Security
Battery WHITE (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/WHITE (-) ABOVE HOOD RELEASE "BRN PLUG"
Trunk Trigger GREEN/BLACK (-) ABOVE HOOD RELEASE "GRN PLUG"
Hood Trigger N/A
Alarm Disarm N/A
Parking Lights RED/BLACK (+) AT FUSEBOX IN DRIVER'S KICK
Convenience
Headlights-Lo BLUE/RED (-) AT LIGHT SWITCH
Wipers-Lo BLUE (-) LEFT OF COLUMN "BRN PLUG"
Trnk Release ORANGE/SLV DOTS (+) IN HARNESS DRIVER FRONT DOORSTEP
Remote Start
Ignition 2 WHITE/BLACK (+) IGNITION SWITCH HARNESS
Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
Anti-Theft Descript NONE
Key Sense BLUE/WHITE (-) IGNITION SWITCH HARNESS
Neutral Safety GREEN/WHITE (-) 12 PIN CONN GEAR SELECT SWITCH
Tachometer BLUE (-) AT DISTRIBUTOR
Speed Sense ORANGE (AC) LEFT FENDER GRAY 6 PIN PLUG
Brake Lights GREEN/WHITE (+) AT BRAKE SWITCH
Reverse Lights GREEN/BLACK (+) 12 PIN CONN GEAR SELECT SWITCH
Horn LIGHT GREEN/BLUE (-) AT STEERING COLUMN
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock BLACK/RED (-) NEGATIVE TRIGGER
CAN BE FOUND IN A GRAY PLUG WITH BLUE TAPE AROUND IT IN SOME VEHICLES.
PowerLock BLACK/WHITE (-) UNDER THE CARPET BELOW FUSE 2 PIN PLUG
LF Window Up LF:RED/BLUE
RF Window Up RF:BLUE/YELLOW
LR Window Up LF:RED/YELLOW
RR Window Up RR:YELLOW/GREEN
What you do with this is none of my business, nor am I responsible for any mishaps or havoc you create when using them.... unless you do something totally cool. Then its all me.
Edit:
I forgot to mention, if you are going to be using this as a guide to wiring in your cb, make sure that you test the wires first. These are known to be wrong here and there from time to time. This one is very spot on but remember shit happens. Just use a multi meter or a test light before you use the wire and make sure its actually the one that it says. With that said, good luck.
Audio/Mobile Video
Radio Security YES
Security
Hood Trigger N/A
Alarm Disarm N/A
Convenience
Remote Start
Modules
WIRE LOCATION
Doorlocks/Windows
Edit:
