Old 04-05-2007, 05:35 PM   #1
Tenji
Tenji is cool... so far.
Starting car in cold weather with no antifreeze
Well, I just got a new car from down south which probably doesn't have any antifreeze in the coolant system. Well, I totally forgot about it and started up the car after it just snow and had some cold weather here. I heard what sounds like ice cracking and the car shuts off. I start it up again and it was fine, now I see some water leaking underneath the car. I'm thinking it made be my water pump, but could it be something else. Thanks.
Tenji is offline   Reply With Quote
Old 04-05-2007, 06:20 PM   #2
mozzandherb
I like turtles
mozzandherb is cool... so far.
The water could possibly be what was in the radiator instead of anti-freeze, you might have a radiator leak.
SOLD!!
Boosted H22
375whp 298 ft/lbs at 15psi
MEMBERS RIDE THREAD<<<CLICK FOR VIDS AND COOL PICS
Other Rides:
-2001 Integra Type R CDM-SOLD
-1990 Honda CRX EF8-ls/vtec-Turbo
-2006 Mazda 3
mozzandherb is offline   Reply With Quote
Old 04-05-2007, 06:22 PM   #3
NAiL05
CB7Tuner Member
Location: Dallas, Waco, And now SIUC for school I'm going worldwide bitches!!!
NAiL05 seems to have made some friends!
YOu dont mix antifreeze with your water and it snowed ouch. Since I have been up in Carbondale (knowing I have a leak) I always keep antifreeze with the water no matter what because it prevents freezing inside your cooling system. But I would fill the system with some fluid at least. ALso make sure where that leak is exactly coming from.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
NAiL05 is offline   Reply With Quote
Old 04-05-2007, 11:20 PM   #4
Turbo Dave
Turbo Dave should be shot.
Send a message via AIM to Turbo Dave
maybe just a hose froze and cracked i dunno how effing cold was it?
Turbo Dave is offline   Reply With Quote
Old 04-05-2007, 11:38 PM   #5
N9netwoAccord
N9netwoAccord seems to have made some friends! N9netwoAccord seems to have made some friends!
Send a message via AIM to N9netwoAccord
hope you didn't crack the block or anything else....
N9netwoAccord is offline   Reply With Quote
Old 04-05-2007, 11:51 PM   #6
NAiL05
CB7Tuner Member
Frozen cooling systems = no good. Ice = expansion. And thats not good for anything. As I said check around for leaks earlier. COuld be something as simple as a hose.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
