So I'm finally in the crowd of cb7 owners with overheating issues. The last couple of days I've noticed my radiator fans turn on after every single drive. They usually didn't do that unless I drove for a long time. Then today, as I was going to school my temp needle climbed all the way to H. I immediately pulled over and checked under the hood and all was fine. I managed to go back home(while praying I didn't blow the HG) and finally made it home. I started to investigate and found out the following:
1. There are no apparent leaks in the system
2. Upper rad hose is hot/stiff while lower hose is limp and cool
3. Fuse for the fans is alright, not sure about the relay though
4. Fans operate when I turn on AC but they they don't turn on at idle
I did a coolant change(bled the system too) and replaced the tstat with one from autozone. Same problem ensues with the radiator hoses only this time there was a little bit of white smoke coming from the vehicle. As of now I'm thinking about replacing the temp sensors and flushing out the radiator with a hose. I belive it may be clogged. Any input is greatly appreciated.
